richardhughes
Code to check if the switch is pressed
Wed Jun 10, 2015 6:09 pm
I just need to know what the code is to check the central press of the joystick and if it is not pressed, then to loop back and check again, meaning it is constantly checking.
gordon77
Re: Code to check if the switch is pressed
Wed Jun 10, 2015 8:58 pm
How is the joystick connected?
ben_nuttall
Wed Jun 10, 2015 10:39 pm
richardhughes wrote:I just need to know what the code is to check the central press of the joystick and if it is not pressed, then to loop back and check again, meaning it is constantly checking.
The Astro Pi / Sense HAT's joystick is mapped to the up/down/left/right/enter keys on the keyboard. To detect joystick use, use an event loop in PyGame:
Examples:
https://github.com/astro-pi/astro-pi-ha ... oystick.py
https://github.com/bennuttall/astro-pi- ... r_match.py
Former RPF staff. Author of gpiozero and creator of piwheels.
Joseph Burrell
Mon Jun 15, 2015 9:31 pm
Hi. I want to know how to code my Pi so that when I move the Joystick one way, the 'page' which is being shown on the LEDs will move to a different page. Eg. One page shows the temperature, the joystick is moved right, the next page shows the humidity. I don't understand how to do this.
Thanks!
scotty101
Tue Jun 16, 2015 9:14 am
Post some code showing how you currently show each 'page' and how you are reading the joystick buttons and I can help fill in the blanks.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
Joseph Burrell
Fri Jun 19, 2015 8:05 pm
from astro_pi import AstroPi # Imports the Astro Pi
ap = AstroPi() # Changing Astro Pi into 'ap'
import pygame
from pygame.locals import *
import time # Imports the time
t = time
ap.set_rotation(270)
#ap.show_message("Welcome, Tim!", scroll_speed=0.05, text_colour=[255,0,0]) # Shows the message: Welcome, Tim!
X = [255, 255, 255] # Displays the text in white.
O = [0, 0, 0] # No colour
tem = ap.get_temperature() # This gets the temperature from the surroundings
temp = int(round(float(tem))) # Turns the temperature into an integer
t.sleep(3)
# --------------------------------------------------------2--
twenty = [
X, O, O, O, O, O, O, O,
O, O, O, O, O, O, O, O,
O, X, X, X, O, X, X, X,
O, O, O, X, O, X, O, X,
O, O, X, O, O, X, O, X,
O, X, O, O, O, X, O, X,
if temp == 20:
    ap.set_pixels(twenty)
twenty_one = [
O, X, X, X, O, X, X, O,
O, O, O, X, O, O, X, O,
O, O, X, O, O, O, X, O,
O, X, O, O, O, O, X, O,
if temp == 21:
    ap.set_pixels(twenty_one)
twenty_two = [
O, O, O, X, O, O, O, X,
O, X, O, O, O, X, O, O,
if temp == 22:
    ap.set_pixels(twenty_two)
twenty_two = [
if temp == 22:
twenty_three = [
O, O, X, O, O, O, X, X,
O, X, O, O, O, O, O, X,
if temp == 23:
    ap.set_pixels(twenty_three)
twenty_four = [
O, X, X, X, O, X, O, O,
O, O, O, X, O, X, O, O,
O, O, X, O, O, X, X, O,
O, X, O, O, O, X, X, X,
O, X, X, X, O, O, X, O
if temp == 24:
    ap.set_pixels(twenty_four)
twenty_five = [
O, O, X, O, O, X, X, X,
if temp == 25:
    ap.set_pixels(twenty_five)
twenty_six = [
if temp == 26:
    ap.set_pixels(twenty_six)
twenty_seven = [
O, O, X, O, O, O, O, X,
O, X, X, X, O, O, O, X
if temp == 27:
    ap.set_pixels(twenty_seven)
twenty_eight = [
if temp == 28:
    ap.set_pixels(twenty_eight)
twenty_nine = [
if temp == 29:
    ap.set_pixels(twenty_nine)
thirty = [
O, O, X, X, O, X, O, X,
if temp == 30:
    ap.set_pixels(thirty)
thirty_one = [
O, O, X, X, O, O, X, O,
if temp == 31:
    ap.set_pixels(thirty_one)
    t.sleep
thirty_two = [
if temp == 31:
    t.sleep
hum = ap.get_humidity() # This gets the humidity from the surroundings
humi = int(round(float(hum))) # This turns it into an integer
fourty = [
X, X, O, O, O, O, O, O,
O, X, X, O, O, X, O, X,
O, X, X, X, O, X, O, X,
if humi == 40:
    ap.set_pixels(fourty)
pygame.init()
pygame.display.set_mode((640, 480))
ap = AstroPi()
ap.clear()
if event.key == K_DOWN and ap.set_pixels == 'twenty_nine':
    ap.set_pixels == 'twenty_three'
Joseph Burrell
Fri Jun 19, 2015 8:06 pm
Examples:
import pygame
t = time
t.sleep(3)
twenty = [
if temp == 20:
twenty_one = [
if temp == 21:
twenty_two = [
if temp == 22:
twenty_two = [
if temp == 22:
twenty_three = [
if temp == 23:
twenty_four = [
if temp == 24:
twenty_five = [
if temp == 25:
twenty_six = [
if temp == 26:
twenty_seven = [
if temp == 27:
twenty_eight = [
if temp == 28:
twenty_nine = [
if temp == 29:
thirty = [
if temp == 30:
thirty_one = [
if temp == 31:
t.sleep
thirty_two = [
if temp == 31:
t.sleep
fourty = [
if humi == 40:
pygame.init()
ap = AstroPi()
ap.clear()
Fri Jun 19, 2015 8:14 pm
If you're going to post code on the forum can you post it in [code]... your code goes here ... [/code] tags.
That makes the difference between
and
Return to “Astro Pi”
