I have copied over the sample code from the gifthub page for the humidity sensor readings (as it is required in my idea), however whenever I try to run it I get an error saying that there is a "False OSError Humidity Init Failed, please run as root / use sudo"
What does this mean and how can I use sudo in the code to make it work.
Thanks,
