LetHopeItsSnowing
Reading orientation data in a loop
Fri May 15, 2015 2:26 pm
I seem to be experiencing an odd issue.
If I read orientation data in loop say once every 2 seconds after only a few cycles it goes out of sync, if however I read it once every 0.1 seconds it doesnt go out of sync.
To show what I mean I recorded it and uploaded it as an 'unlisted' video to youtube https://youtu.be/MS1Tfv5CifM
This is my code which reads the data every 0.1 seconds and this works perfectly:
from astro_pi import AstroPi
from time import sleep
ap = AstroPi()
ap.set_imu_config(True, True, True)
while(True):
    orientation = ap.get_orientation_degrees()
    print("yaw = {}; pitch = {}; roll = {}".format(orientation["yaw"], orientation["pitch"], orientation["roll"]))
    sleep(0.1)
The same program but with a 2 second sleep, stops working after only a few reads and I get very weird results.
ap = AstroPi()
while(True):
    sleep(2)
Any ideas?
Mart
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
Johnny5C
Re: Reading orientation data in a loop
Fri May 15, 2015 4:54 pm
I have run your code on my pi, and it look OK on first glance. Watching your video were you only changing the yaw to test it?
Davespice
Contact: Twitter
Fri May 15, 2015 4:57 pm
I've confirmed the issue. It's almost as if there is a fifo queue inside RTIMUlib and if you read it slowly you slowly work through movements that have occurred in the past. I'll have a look into this but if the problem is with RTIMUlib then I'll need to get ShiftPlusOne to help.
I have a workaround for you in the meantime.
try:
    import thread
except ImportError:
    import _thread as thread
ap = AstroPi()
orientation = None
def orientation_thread():
    global orientation
    global ap
    while(True):
thread.start_new_thread(orientation_thread, ())
sleep(1)
while(True):
    print("yaw = {0:.2f}; pitch = {1:.2f}; roll = {2:.2f}".format(orientation["yaw"], orientation["pitch"], orientation["roll"]))
    sleep(2)
Johnny5C
Fri May 15, 2015 5:51 pm
Yeah, just tinkering with yaw, I can see that is plays catchup after you stop moving.
But, pitch and roll take big jumps to the new position.
LetHopeItsSnowing
Fri May 15, 2015 6:14 pm
Thanks Dave.
That describes the behaviour I'm seeing perfectly.
ShiftPlusOne
Sat May 16, 2015 2:16 pm
I don't know the internals of RTIMULib's data fusion algorithm. However, it's an iterative process of predicting values and adjusting parameters based on what's measured.
Ideally you'd iterate at the set sample rate.
If I had to guess, that's what this is. The filter can cope with lots of data with relatively small deltas, but if you're only giving it a few iterations per second, the tuning parameters don't really know what to do. It's like trying to determine a trend with 2 data points vs 100.
LetHopeItsSnowing
Sun May 17, 2015 2:11 pm
I have created a sub class of AstroPi to do the job of reading the orientation data continuously for me.
try:
    import thread
except ImportError:
class AstroPiContinuous(AstroPi):
    A class which continuously reads orientation data from AstroPi as without
    it the orientatin data looses sync
    def __init__(self,
            fb_device='/dev/fb1',
            imu_settings_file='RTIMULib',
            text_assets='astro_pi_text',
            sample_rate = 0.1):
        AstroPi.__init__(self, fb_device, imu_settings_file, text_assets)
        self.sample_rate = sample_rate
        self.stopped = True
        self.running = False
    def start(self):
        starts the thread that continuously reads the astro pi orientation data
        #initialise the IMU by getting the orientation
        self.get_orientation()
        #start the orientation thread
        thread.start_new_thread(self._get_orientation_threaded, ())
    def _get_orientation_threaded(self):
        reads the orientation data every sample rate to ensure astro pi is kept in sync
        self.stopped = False
        self.running = True
        #keep reading the orientation data, this keeps AstroPi in sync
        while(not self.stopped):
            sleep(self.sample_rate)
    def stop(self):
        stops the continous read thread
        self.stopped = True
        #wait for the thread to stop
        while(self.running):
            sleep(0.01)
    def __enter__(self):
        self.start()
        return self
    def __exit__(self, type, value, traceback):
        self.stop()
#test
if __name__ == "__main__":
    with AstroPiContinuous() as ap:
        while(True):
            print(ap.get_orientation())
            sleep(2)
It might be helpful to others.
richards-tech
Thu Jun 18, 2015 3:03 pm
That's a good solution. To confirm, it is important that the IMU is polled at the gyro sample rate or greater. The code does a piecewise linear approximation at each time step based on gyro rates so it is important to keep the time steps small. A thread to take of care of that is the way to go.
butchec
Thu Aug 06, 2015 10:52 am
I have been using the above work around for recording the orientation every 30seconds and everything has been working well. We successfully ran it for a full week with a log and picture taken every 30 seconds.
My son was one of the competition winners and for the final submission of our code we were asked to swap to a B+ in place of the B2.
All of our code is working well except for the orientation work around. The python program crashes out every time I run the program and include the module with the workaround code.
If I move the code back across to the B2 all is good.
Can anyone help with this? We need to post our final submission before Monday.
Both the Raspberry Pi B+ and the B2 are fresh installs with all of the latest updates. I have no problem running any code or program I have created except when I add the workaround module.
I also tested recording the orientation every 0.2 seconds and all was well, but as soon as i swap back to every 30 seconds and use the workaround it crashes on the B+
Cheers.
Chris
Return to “Astro Pi”
