version: Astro_Pi_PILOT V2.0.30
Astro_Pi3_Enclosure_3D_PRINT_SECTION_2 V2.STL
Astro_Pi3_Enclosure_3D_PRINT_SECTION_3 V2.STL
Astro_Pi_Enclosure_3D_PRINT_SECTION_1 V1.STL
Astro_Pi_Enclosure_3D_PRINT_SECTION_2 V1.STL
Astro_Pi_Enclosure_3D_PRINT_SECTION_3 V1.STL
Astro_Pi_Enclosure_3D_PRINT_SECTION_4 V1.STL
Astro_Pi_Enclosure_3D_PRINT_SECTION_4_PILOT V2.STL
above bold stl files was the source files for reverse-engineer.
( came from: https://www.raspberrypi.org/blog/astro- ... ight-case/
https://github.com/raspberrypilearning/ ... master/STL )
the picture right is the release version by Rpi.
the left is the reverse-engineer version.
Re: reverse-engineer Astro_Pi_PILOT stls
file version: Astro_Pi_PILOT V2.0.36
- mix 2nd & 3rd part together ( left is reverse-engineer version, right is the Rpi released. )
- Rpi Boss distance is 58mm x 49mm.
