Touchchat style app for a touchscreen using a pi
Posted: Mon Mar 11, 2019 3:21 pm
by classz123
:?: I developed the hardware configuration for a cheaper alternative for an aac device but I need software to fully support nonverbal students.
I need an app that I can put a word or picture into a block and once pressed it would say the programmed word. I know Espeak exists but it only uses the keyboard. I need something that i can put a pec or phrase into and allow the child to speak.
Any suggestions?
Re: Touchchat style app for a touchscreen using a pi
Posted: Mon Mar 11, 2019 4:45 pm
by scotty101
Are you looking for an existing App or are you looking for help to write one yourself?
I seem to recall a similar project before but can't find it.
Posted: Mon Mar 11, 2019 8:54 pm
by Imperf3kt
How many words do you need?
I know of one program that can easily do this, and could possibly build you a sample, but this isn't its intended purpose, so would require manually adding every single word you'd ever want to use.
It's support on the Raspberry Pi is currently minimal / experimental and it only works on a Pi2b or Pi3b / Pi3b+
I am yet to test it on a Pi3A+. I suspect it will work, but the limited RAM of a Pi3A+ is a slight concern.
Posted: Tue May 28, 2019 2:24 pm
by mmk8283
I used this instructable and modified it to work with capacitive touch sensors. but I think this is what you are looking for.
https://www.instructables.com/id/Playba ... pberry-Pi/
viewtopic.php?f=102&t=225035
