Soldering with only left arm.
Posted: Mon Nov 14, 2016 7:19 pm
by Windcheetah
Hi everyone, I have been run down by a transit van while on my bicycle.
This caused me to have no feeling or movement in my right hand.
The question is, has anyone mastered soldering with 1 arm/hand??
Pi's are topps!!!!
Martin
Re: Soldering
Posted: Mon Nov 14, 2016 7:29 pm
by mikronauts
Sorry to hear about your accident!
1) Look for pcb holders http://ca.mouser.com/Tools-Supplies/Too ... /_/N-11uop
2) buy/make some sort of "solder pen" that you can hold/direct with your mouth http://www.digikey.ca/product-detail/en ... ND/2177387
3) get some safety glasses
4) ideally also get a fume extractor
Windcheetah wrote:Hi everyone, I have been run down by a transit van while on my bicycle.
Pi's are topps!!!!
Martin
Re: Soldering
Posted: Mon Nov 14, 2016 7:41 pm
by gregeric
Hi Windcheetah. As well as the above, maybe it's worth trying soldering paste instead of solder. Apply a blob of paste to the joint, then pick up your iron & melt it.
Re: Soldering
Posted: Wed Nov 16, 2016 1:20 pm
by Windcheetah
Thanks loads for the suggestions.
Martin
Re: Soldering
Posted: Thu Dec 01, 2016 6:16 pm
by KMyers
Sorry about your accident. I was also in an accident in 2004, hit and run type. Was an RF engineer who liked to build things (solder). Was very difficult to solder using one hand. I find the most help comes from holding the board secure with tape, using a magnifying lite and smallest solder. I can do it but it takes much longer then before. Also if you can get a variable temp iron.
Good luck keep soldering! :D
Ken N8SYG
Re: Soldering
Posted: Thu Dec 01, 2016 6:44 pm
by lpsw
Hi Windcheetah. Sorry to hear about the accident. gregeric's suggestion is what I've been using for a while. Had a little issue after a fall climbing in Scotland in 1987. Been soldering with mouth and left had hand since then, until I found soldering paste.
gregeric wrote:Hi Windcheetah. As well as the above, maybe it's worth trying soldering paste instead of solder. Apply a blob of paste to the joint, then pick up your iron & melt it.
Re: Soldering
Posted: Thu Dec 08, 2016 10:41 am
by Windcheetah
Thanks very much for your thoughts, I think I'll give the solder paste a shot.
Martin
