ssl303
Espeak With Bluealsa For Speech Feedback
Sat Jun 27, 2020 11:41 pm
I'm trying to implement speech feedback for a device I'm creating for a blind user.
I'm on 2020-05-27-raspios-buster-lite-armhf.img, and I can't get espeak to speak through Bluealsa.
I'm including ~/.asound at the bottom, and I did not touch any other alsa configuration that comes with PiOS as default.
I'm working on Python, so hoping to be able to use speake3.
I can play audio using pyaudio on Python, but not speake3 on Python.
Also if I route espeak to aplay in terminal, it works.
$ espeak "hello" --stdout | aplay
Playing WAVE 'stdin' : Signed 16 bit Little Endian, Rate 22050 Hz, Mono
If I just use espeak by itself, I get the error at the bottom, and it hangs.
I appreciate any help!
Here's my ~/.asound
pcm.!default {
type plug
slave.pcm {
type bluealsa
device "00:1E:7C:50:95:E4"
profile "a2dp"
Here's the error.
$ espeak "Hello"
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5036:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM bluealsa
ALSA lib bluealsa-pcm.c:763:(_snd_pcm_bluealsa_open) Couldn't get BlueALSA PCM: PCM not found
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Return to “Assistive technology and accessibility”
