TheGoodTheBadTheUgly
Help making a soundboard run on startup!
Thu Jun 20, 2019 8:34 pm
Hey guys, first off, I am a complete noob when it comes to programming and even more python.
I am designing a Tactile Map to help a blind person navigate through a building. The tactile map has an audio component which is basically a soundboard created with Raspberry Pi 3 and where a sound queue is played when a button is pressed.
I managed to make the soundboard work. When I run the program and press the button, a sound file plays!
The problem is that I would like the script to run on startup. I read a bit and tried to add the file to open on startup with Crontab and changed boot parameters so I don't need to log in, but when I press the button, I only hear static and now my sound file. I am guessing that the startup parameters worked to run the script but not to open the sound file.
Anyways, I hope someone will be able to help me with this. I thank you all!
Andyroo
Re: Help making a soundboard run on startup!
Thu Jun 20, 2019 9:41 pm
How did you start the program from the terminal?
Can you post the CRONTAB entry please?
crontab -l
pcmanbob
Tue Jul 16, 2019 11:23 am
Hi.
One thing to be aware of is that cron runs in a different environment to the command line, so you need to add full paths to any files
( like your sound files ) that you might call or use in your program.
You should also use full path and file name in your cron line as well, IE. python /home/pi/myfile.py
Tue Jul 16, 2019 4:47 pm
Start if from the desktop autostart file. That's where I get my Google AIY stuff running.
Either /etc/xdg/lxsession/LXDE-pi/autostart or a .desktop file in /etc/xdg/autostart with Buster.
This is a doctor free zone.
Return to “Assistive technology and accessibility”
