simja
Microstack Accelerometer problem with usage
Tue Jan 31, 2017 3:13 pm
Hey guys,
i'm working on a project and at this point i tried to install and use the Microstack Accelerometer AAM8452Q. I had a few problems with it (i have one of the boards, where the pins were not connected, but i soldered it and now it works), but i can execute the example and it works fine.
My problem now is, that i wanted to write my own python program basing on the used functions in the example. So i created a file in my projet folder (/home/...) and wrote the following code:
import microstacknode.hardware.accelerometer.mma8452q
with MMA8452Q() as accelerometer:
 while True:
  print(accelerometer.get_xyz())
I got the following Error: NameError: name 'MMA8452Q' is not defined.
So i tried another possibility described from Microstack:
accelerometer = microstacknode.hardware.accelerometer.mma8452q.MMA8452Q()
while True:
That delivers another error:
File "/usr/lib/python3/dist-packages/microstacknode/hardware/accelerometer/mma8452q.py", line 194, in get_xyz
buf = self.transaction(reading(self.i2c.address, 7)) [0]
File "/usr/lib/python3/dist-packages/microstackcommon/i2c.py", line 85, in transaction
ioctl(self.fd, I2C_RDWR, ioctl_arg)
AttributeError: 'MMA8452Q' object has no attribute 'fd'
I looked up the i2c.py and it needs that attribute, i have no idea, why this error occurs.
I hope someone can help me, i really fall into despair :(
Return to “Add-ons”
Who is online
Users browsing this forum: No registered users and 4 guests
