matteoraggi
Cheapest wifi usb dongle for pi3 model B
Thu Jan 12, 2017 12:39 am
Hi to all! I love raspberry and I am managing 9 of them, dreaming to became an expert and manage hundreds of them.
After installing these few, I discovered that the internal wifi is wonderful, but the antenna is too much little and weak, and oftne it don't find normal wifi signal. Now my question is: which is the cheapes usb wifi dongle compatible with raspberry? Because I would be happy to pay few more euro (and not 15-30€ for a super-gun antenna) and power up the wifi signal of my lovely raspberries :-)
Raspberry Pi 3 model B - Raspbian 8 Jessie
gregeric
Re: Cheapest wifi usb dongle for pi3 model B
Sat Jan 14, 2017 10:54 am
fruitoftheloom wrote:Purchase the RPi 2B v1.2 which has the BCM2837 SoC
There's no need to replace the 9 Pi3 - dtoverlay=pi3-disable-wifi will be in future firmwares, and you can blacklist the modules for now.
alphanumeric
Thu Jan 19, 2017 2:01 pm
Are you any good at surface mount soldering? Have a look at this, http://raspberrypi.stackexchange.com/qu ... -to-a-pi-3
matteoraggi
Thu Jan 19, 2017 5:50 pm
Thanks but I need a solution that I can buy in Europe and that is easy and quick to setup, without break the warranty.
This of 6€ is a cheap solution compatible with raspberry, easy, quick and don't break warranty:
https://www.amazon.it/Adattatore-USB-Wi ... +wifi+nano
Here there are also other cheaper, but how I can know if the yworks with raspbian 8 and raspberry pi 3 model B?
1€ at 150mbps:
http://www.ebay.it/itm/Antenna-Nano-Min ... Swo4pYHD8F
or 3,5 €:
https://www.amazon.it/150-m-802-11-N-Ad ... +wifi+nano
alphanumeric
Thu Jan 19, 2017 6:04 pm
Just giving idea's alternatives. You can get the connectors here, https://www.adafruit.com/products/1661 for less than a buck each. They also have the cables and antennas to go with them. https://www.adafruit.com/products/852 I can understand why you wouldn't want to go that route though. You need the skill and resources to modify the boards.
alphanumeric
Thu Jan 19, 2017 6:08 pm
You get what you pay for by the way. Go too cheap on your dongle and you may find the range isn't any better than what you have now. I've used these in the past with my 2B's. https://www.adafruit.com/products/1030 Good range and they work out of the box, plug and play with Raspbian. No drivers of file edits required.
UK_Ham
Thu Jan 19, 2017 6:44 pm
I know people are offering solutions but before I am say what to go for, what is the distance to router from the various pi's? Also screening like walls etc in the way, possible other obstacles could also be affecting the signal,
Name is Mike, Radio Ham and Weather Nut.
Total Beginner with Rpi Zero
matteoraggi
Thu Jan 19, 2017 6:48 pm
Nothing special, I just need a normal wifi, because the basic raspberry wifi antenna is very weak about the distance for my experience. I experienced 9 raspberry with wifi and when distance was more of 5-10 meters without walls (or other obstacles) from the wifi bridge or router, I was starting then ot have troubles, instead with normal smartphones it was all right.
If I was needing a super antenna I was asking for that, I just need one normal and cheap, because need to buy it multiple times for multiple raspberry..
UK_Ham
Thu Jan 19, 2017 6:58 pm
matteoraggi wrote:Nothing special, I just need a normal wifi, because the basic raspberry wifi antenna is very weak about the distance for my experience. I experienced 9 raspberry with wifi and when distance was more of 5-10 meters without walls (or other obstacles) from the wifi bridge or router, I was starting then ot have troubles, instead with normal smartphones it was all right.
That helps a lot, Maybe just a booster antenna on the Wi-Fi hub. the logical solution in my book would be buy one dongle at the price you would be prepared to pay for each unit and try it.
That way you would not loose out too much if not sucessfull
matteoraggi
Thu Jan 19, 2017 7:01 pm
Thanks! the wifi hub has already 2 big antennas or 3... For now I patched with a LAN cable rj45 to 7 of the 9 raspberry, and the other 2 are at about 5 meters and never has problems of wifi signal. but people with normal smartphones at 15 meters never have instead problems with wifi signal..
Antonino
Mon May 22, 2017 3:16 am
Hi everybody,
I'm posting here because I had the same exact dilemma some days ago and I found an amazing 4G based solution
After reading guides on usb_modeswitch, sakis, wvdial I saw that usually Huawei modems were the ones with more support pages from the forums and tutorials, so this helped me in choosing the brand. The choices I could do here in Australia were E3372 with Optus and E8372 with Telstra. I picked up this last one because my company had already a Telstra SIM available
I was literally impressed by the easy setup of this device. First I plugged it on Windows 10 [just to check if it was working in general] and after on Raspbian Jessie running on Raspberry Pi 3. At the very beginning I did a firmware upgrade on Windows through the modem home page and after it worked straight away on both platforms. The zero configuration on Raspberry Pi 3 was over expectations, as I said before I read on multiple blogs that there is a lot to do to make them work on this platforms, even with other devices from the same brand
Unfortunately Telstra doesn't indicate clearly at all the model, you don't even know what you are buying. I could see that it was this device from product code thanks to the shop assistant and cross-checking with the image online. For people without codes if you want to buy this E8372 wingle you will find TPREPAID 4GX USB+WI-FI PLUS WHT 3GB out of the telco box. If you slide the modem lid there is an additional name spec which is fully featured as E8372h-608. Power consumption is 750mA from the booklet, so basically in line with other devices
SIM size to make it work is a full SIM [2FF] so if you are in the situation where you have already a Telstra SIM better to find a SIM adapter before
Overall: excellent, highly recommended
Hope this can really help
Have a good day mates,
Antonino
dcavni
Thu Dec 28, 2017 9:18 pm
Can you define Zero Configuration, did you use 3g configuration in Pi or just WIFi option from E8372 and connectd Pi to Wifi? Does dongle works connected directly to PI?
I'm trying to make, a 3g/4G videosurvailance with Pi Zero W and USB modem. For now i have it connected through MiFi, but i don't like the fact, that Mifi's battery should be on charge all the time. Pi Zero then uses OpenVPn to connect home and i can see him like local network device.
