Fizgriz
USB to ethernet Adaptor
Thu Oct 08, 2015 1:43 am
I'm building a firewall with my Pi B+ model and was curious if any of the USB to Ethernet adapters are usable on the pi? Or which ones work better. I need two LAN ports for this to be successful and sit between the client and router. Thank you in advance :) :D
Re: USB to ethernet Adaptor
Thu Oct 08, 2015 5:35 am
Many of them work. Try to avoid the really cheap ones on ebay and the like as they use the DM9601 chip set which has a bad bug in the driver (that might have been fixed by now, I haven't bothered to check) and is only USB 1.1 giving you a maximum of 12Mb/s over the USB even though the chip supports 100Mb/s ethernet. They are advertised as "USB 2.0 compatible" which means they will work with USB 2.0 - just not at USB 2.0 speeds :shock:
I've used an AX88772 based adaptor with no problems. It was still quite cheap and a bit more flexible as it has a short USB lead rather than plugging in directly.
FTrevorGowen
Thu Oct 08, 2015 7:36 pm
rpdom wrote:Many of them work. Try to avoid the really cheap ones on ebay and the like as they use the DM9601 chip set which has a bad bug in the driver (that might have been fixed by now, I haven't bothered to check) and is only USB 1.1 giving you a maximum of 12Mb/s over the USB even though the chip supports 100Mb/s ethernet. They are advertised as "USB 2.0 compatible" which means they will work with USB 2.0 - just not at USB 2.0 speeds :shock:
+1 (the DM9601 driver issue led to some of my first posts!)
FWIW, some brief notes/images of the devices I've tried out are here:
http://www.cpmspectrepi.webspace.virgin ... pters.html
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
plugwash
Thu Oct 08, 2015 7:54 pm
rpdom wrote:They are advertised as "USB 2.0 compatible" which means they will work with USB 2.0 - just not at USB 2.0 speeds
Note that the USB 2.0 spec defines three speeds ("low", "full" and "high") and that it is perfectly possible for a device to be designed to and compliant with the USB 2.0 specification while only supporting "full speed".
Thu Oct 08, 2015 8:04 pm
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
pvogel
Sun Oct 23, 2016 7:56 pm
I am looking for a known good USB to ethernet adaptor that does not require power from a hub, anyone got a recommendation (don't care about price, want it to work with my rPi3!).
FTrevorGowen
Mon Oct 24, 2016 2:34 pm
pvogel wrote:I am looking for a known good USB to ethernet adaptor that does not require power from a hub, anyone got a recommendation (don't care about price, want it to work with my rPi3!).
Just in case you tried to follow the, now invalid**, link in my old, 2015, post the updated info. is now here:
http://www.cpmspectrepi.uk/raspberry_pi ... pters.html
Trev.
** My ISP dropped webspace support a while ago and I had to relocate my webpages!
Mon Oct 24, 2016 2:46 pm
Realtek work AOK:
USB 2.0 Realtek RTL8152 Chipset
USB 3.0 Realtek RTL8153 Chipset
This Blog writer is using an USB 3.0 adaptor with a ASIX AX88179 Chipset:
http://www.jeffgeerling.com/blogs/jeff- ... networking
adieu
Jeffreymox
Contact: ICQ Website
Sun Mar 26, 2017 7:59 pm
Cant you use an ethernet hub or switch? The mcmix/controls are tcp/ip devices so should work through normal Ethernet routing equipment. A USB adaptor doesnt sound like a great idea.
