tonychang-uk
4 Port RS232 for Raspberry Pi 2B 3B & PI Zero
Tue Jun 06, 2017 4:59 pm
4 Port RS232 for Pi Zero/W, 2B, 3B , A+, B+
1. Provide RS232 x4 DB9 or RJ45 output
2. Can Choose RS232 x2 & RS485 X2
3. On board DS18B20 1Wire Temperature sensor (Option)
4. Provide 8 GPIO control LED
5. 1 GPIO 5V Mini Fan control pin (On/Off control) ( 2.0mm / 2.54mm pitch )
6. On board RTC function with CR1220 Battery socket
7. 4 x RS232 Board Power select jumper from Pi or Micro USB
8. 5V Mini Fan Power select jumper from Pi or Micro USB
9. It provides an individual 3.3V power for UART Board
10. Provide HAT EEPROM for future driver program update.
11. One software control Micro Switch for Program ( Shut Down , reboot....)
12. Use 20x2 40pin cable connect to Pi
13. PCB size 110mm x 85mm
14. Raspberry Pi model 3B & Pi Zero W still can use on board Bluetooth & WiFi
product detail
4 x RS232 4 Port RS232
http://www.pridopia.co.uk/rs-pi-i2c-rs232-4.html
2x RS232 2X RS485 2 Port RS232 2 Port RS485
http://www.pridopia.co.uk/rs-pi-i2c-rs232-rs485.html
4 Port RS232 for Pi Zero 3B 2B
tonychang-uk
Re: 4 Port RS232 for Raspberry Pi 2B 3B & PI Zero
Wed Jun 07, 2017 8:43 pm
tonychang-uk
Sat Jun 17, 2017 10:36 pm
GPIO pin control RJ45 LED
RJ45 LED control by GPIO pin
Martin Frezman
Sun Jun 18, 2017 10:26 am
I'm sorry I missed it.
Your support question is?
If this post appears in the wrong forums category, my apologies.
tonychang-uk
Wed Jul 05, 2017 8:24 am
Martin Frezman wrote:I'm sorry I missed it.
What's support question? Where is the support question? Sorry , I don't understand.
or you means question and answer?
http://www.pridopia.co.uk/rs-pi-i2c-uart-q-a.html
rpdom
Wed Jul 05, 2017 8:59 am
Don't worry about it. Obviously Freezman mistook this for a support only forum and has decided that your post doesn't fall into that category and was trying to be a self appointed moderator clever. He failed.
tonychang-uk
Mon Nov 20, 2017 6:03 pm
4 x UART Box 200mm x125mm x 55mm
4xUART -> RS232 X2, RS485 x1 , RS232/RS485 x1
Product detail
http://www.pridopia.co.uk/rs-pi3-i2c-rs232-rs485.html
Return to “Add-ons”
Who is online
Users browsing this forum: Google [Bot] and 6 guests
