Identifying the Pi over the network
39 posts   Page 2 of 2   1, 2
by meltwater » Tue Sep 04, 2012 2:56 pm
droople wrote:
texy wrote:Well despite the dhcp update procedure above, my pi is still 'UNKNOWN' by my Sky router. I seem to have a constant ip address unless I reset the router of course, but its still UNKNOWN. So in order to connect via putty or vnc, I put in the ip of the pi, not the name. Its no big deal to me, but I,d still like to get to the bottom of it.
Texy
I have the same issue :(
I find the hostname works on some networks but not others and for different things. Home network, hostname is fine for everything. Work network, it is fine for vnc, shh, but not smb (annoying, but still enough to work with - shh in to get the ip etc). You'll probably find that the ip address will stick on a network for 24 hours or so, as they get allocated and expire.
You could also try setting a fixed ip address on the Rpi, although that is only useful if keeping on a single network (some routers will allow you to set a static DHCP ip address too - assuming your mac stays put).
_________________________________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
Released at the start of each month.
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
by wallarug » Tue Dec 11, 2012 1:10 am
I have no luck in getting RPi hostname to work.
I have a strange issue.
The hostname is broadcasting to the router but I can't ssh, vnc and others into it.
I posted http://www.raspberrypi.org/phpBB3/viewtopic.php?f=27&t=10071&p=230854#p230854 but still no responces.
Youtube Channel: http://www.youtube.com/user/wallarug?feature=mhee
Project page: http://code.google.com/p/cmd-robot/
by Mursili » Tue Dec 11, 2012 3:36 am
What distro are you running?
I am running debian wheezy and I can ping raspberrypi.local practically out of the box. It just works after I set up the network. I have not tried to ssh in.
by wallarug » Tue Dec 11, 2012 4:47 am
Mursili wrote:What distro are you running?
Raspbian.
I didn't put in '.local'? Should I have?
by Mursili » Tue Dec 11, 2012 2:52 pm
On my network at home I can ping (or ssh if I have that set up on a machine) their hostname.local by default. Just setting a hostname on one machine does not make other machines on the same network necessarily use that hostname. By default, my network requires me to use hostname.local. I can edit /etc/hosts on the machine I will be ssh'ing from to refer to the other machine if needed.
I suggest that your try pinging the machine using the hostname followed by .local and see if that works any differently. If it does, it simply means that you need to keep using the .local or edit your /etc/hosts file or find another solution.
by efflandt » Thu Dec 13, 2012 7:34 am
NOTE: If you change /etc/hostname on the Pi also change that name in its /etc/hosts.
Not sure if it is necessary, but I installed avahi-daemon on my Pi, and Ubuntu Linux has avahi installed by default. That is what allows you to find other computers on the LAN by their hostname.local without having to configure samba for Windows file and printer sharing. Bonjour works for that, which I think comes with Apple and is available for Windows computers. By default avahi is only configured for ssh, so for something like vnc you would need to figure out how to add a file for that to /etc/avahi/services. Although, it works for ping.
efflandt@XPS8100-1204:~$ ping -c2 raspberrypi.local
PING raspberrypi.local (192.168.1.103) 56(84) bytes of data.
64 bytes from raspberrypi.local (192.168.1.103): icmp_req=1 ttl=64 time=3.28 ms
64 bytes from raspberrypi.local (192.168.1.103): icmp_req=2 ttl=64 time=2.89 ms
--- raspberrypi.local ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 2.896/3.088/3.280/0.192 ms
by fatcinco » Thu Dec 13, 2012 7:49 am
Quick bash script to get avahi and netatalk up and running.
https://gist.github.com/raw/73230119a9a ... NSforPI.sh
by willyt » Fri Dec 28, 2012 10:05 pm
avahi is great and is a good solution for the ip address problem. You don't need to edit hosts or hostnames, just sudo apt-get install avahi-daemon to get going.
If you have vnc installed and set up to start on boot on port 5901 you can also advertise the vnc service as well as ssh. Use nano to create a new file like this in the terminal:
sudo nano /etc/avahi/services/vnc.service
and paste this into it
<?xml version="1.0" standalone='no'?>
<!DOCTYPE service-group SYSTEM "avahi-service.dtd">
<service-group>
  <name replace-wildcards="yes">%h</name>
  <service>
    <type>_rfb._tcp</type>
    <port>5901</port>
  </service>
</service-group>
hit ctrl-x then Y then enter to save
If you are on a mac, the raspberry pi will show up in the sidebar of the finder after you reboot your pi and you can start a screen sharing session by clicking the share screen button
For ultimate smoothness you can create an ssh key on your main machine and scp the public key to your pi so you don't need to type a password to login.
by bugloss » Fri Jan 04, 2013 2:54 pm
Hi
First post.
I'm trying to activate a screen sharing session with the pi and a mac book air running Lion.
I've gone through all the steps as you set out and I can connect to the Pi with the Mac finder.
When I try to share the screen I get a dialogue box on the mac
"Connection failed to “raspberrypi”.
Please make sure that Screen Sharing (in the Sharing section of System Preferences) is enabled on the computer to which you are attempting to connect. Also make sure your network connection is working properly."
What am I missing here and am I supposed to see a RasPi screen in a separate window?
Hope someone can help.
by willyt » Wed Jan 09, 2013 8:55 pm
Hi there, you either need to install and configure a vnc server or your vnc server is not configured to start on boot, follow the instructions here:
http://elinux.org/RPi_VNC_Server
Edit: Assuming you are using the default username and you haven't changed the hostname of your raspberrypi you can connect to the pi over ssh from terminal on your mac by typing
ssh pi@raspberrypi.local
and then entering following the instructions at the link above.
Hope this helps,
W
by bugloss » Wed Jan 09, 2013 10:03 pm
Thanks, I'd managed to figure it out immediately after posting my issue as I stumbled accross the link that you mentioned.
Crikey I think I'm in for a mega Python cramming session as this means nothing at all to me. :o
by mmbcastle » Fri Feb 15, 2013 1:51 pm
As to the MAC address, I've read that the Pi is limited to 10/100 operation because they're running the ethernet through the USB controller. I'd suspect that's the reason for a "soft MAC address".
For a LOT of reasons, it would be very handy to have a way to broadcast the Pi's IP address. I'm researching the code to make a utility to do that. My goal is to make it transmit so a setup program can find it, then give it a fixed IP. Alternately, I may have the utility find it each time a user wants to talk to the Pi, then launch a web page hosted on the Pi.
Most routers don't have DNS enabled, so they won't care about the Pi broadcasting its name. They may list the name in internal tables, but probably won't help you find the device by name. I'm away from my Pi right now. When I get home. I hope one of these solutions will give me a solution for my development machine, but I need something more general.
Edit: Duh! Didn't see page two. Looks very promising.
by bingnet » Tue Mar 05, 2013 11:45 pm
How to use OS X to locate on the network, login to, and secure your brand new Raspberry Pi running Raspbian “wheezy”.
https://plus.google.com/115605293947059 ... MqeMY9p3gw
by mmbcastle » Wed Mar 06, 2013 2:24 am
One thing I've been exploring a bit is netcat/nc. It has a lot of potential for making a simple service where you could send a broadcast on a certain port and have the Pi respond with its IP address.
This wiki entry has some interesting examples to build on.
http://en.wikipedia.org/wiki/Netcat
Bill
