I've got a few questions related to this.
1. Has Mencoder/FFMpeg stated that they will update to support the GPU encoding features of the pi?
2. The codecs in the store - are they only for hardware encode/decode, or does it limit software encode/decode too?
3. Why does a standard desktop not require purchasing additional codecs before they work?
I've managed to get it converting at about 13fps, if I could just eek a bit more out I might be able to do it.
MiniDLNA Transcode - Hardware MPEG-2 Encoding?
Been reading around, still cant find any more info or answers on my question.
1) Nope. We have a "omxtx" proof-of-concept transcoder though.
NOTE : Both the OpenMAX API and libraries are cost-free
and open , but that doesn't seem to have helped much.
2) Hardware only.
3) This thread shows some very good arguments :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=63&t=4704#p62978
And AFAIK the foundation is trying hard not to get sued.
The point is : The CPU of the Pi is simply too slow for
software en/trans/decode.
ghans
2) Hardware only.
ghans
Brilliant answers, thank you!
With regards to point 3 - Does that mean normal PCs don't need them due to everything being done in software, since as you said in point 2 the codecs in the store are only for a hardware encode license?
Jademalo wrote:Brilliant answers, thank you!
Sort of. Technically, SW codecs should also pay the licence, but that has never been/is impossible to enforce. With HW codecs, it's easy for MPEGLA to say - that's on, you owe us
- Moderator
Aaah, I see.
Is that one of the reasons why the high end encoding software like Premiere etc. are so expensive? Since they have to licence the codecs properly?
Jademalo wrote:Aaah, I see.
No, the actual licences fees are pretty low, just a few dollars/device. But because even a few dollars is a good percentage of the Raspi selling price, we don't put them all on as standard. I guess the high end encoders are expensive because they are very effective - i.e. better compression ratios for similar quality levels. But that is a guess.
- Moderator
Oh, that makes sense. Pure proportion.
One last question - Are hardware encoding licenses based on the chip that is doing the encoding, the device as a whole, or is it related to the user? (I'm assuming chip - but I was curious if it was in any way transferable)
jamesh wrote:Jademalo wrote:Aaah, I see.
High end encoders are expensive because:
1. The market is relatively small so when the development cost is spread across the number of units sold it adds a lot.
2. Users of high end encoders are usually both able and prepared to pay the high prices.
Bear in mind that the MPEG video specs really only define how a coded bit-stream should be 'interpreted' by a decoder. There is a great deal of scope for two different encoders to take the same video input signal and produce two encoded versions from which a decoder can reconstruct two approximations to the original. But the bit-rate versus subjective quality characteristics of the two can be very different.
