Has anyone got a good (e.g cheap) source for a 26 way female PCB socket.
I'm talking about one that;s used on things like the pico board http://www.piborg.org/picoborg
and not a ribbon cable type one.
Regards
Simon
26way female socket
Page 1 of 2 1, 2
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
One thing I really hate is when someone says they want something that is "cheap", which is no use without a target price or what you want to be cheaper than.simplesi wrote:Has anyone got a good (e.g cheap) source for a 26 way female PCB socket.
Most distributors Farnell.RS/CPC/Rapid/Arroiw and many others have hundreds of similar parts
I personally use the 3M 8526-4500PL
http://uk.farnell.com/3m/8526-4500pl/socket-pcb-26way-2row/dp/9138650?Ntt=8526-4500PL
Cheaper from CPC
http://cpc.farnell.com/3m/8526-4500pl/s ... tt=CN12879
They also have plenty of PCB data connectors on 2.54mm or 0.1 inch pitch double row, like the one on that board.
I suggest you have a look for what you want as also just going for cheapest may also find a connector that falls apart at a moments notice or has other problems.
There is cheap and cheap within specifications for usage requirements
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
It depends on how many you want to buy.
Oh, I've missed our little disucssions so much
Let me explain....
A few suppliers are now selling little add-on PCB boards for about £5 which is a lot "cheaper" than the original £10 ones.
But for a "cheap" project even £5 isn't "cheap" enough so me and a mate of mine thought is we could get hold of a "cheap" 26 way connector, then we could solder it to a "cheap" piece of veroboard clone and make "very cheap" expansion boards
My basic Robot controller consists of 1xULN2003 connected to the RPi by 3 wires and to battery and 2 motors.
Now at the moment, the "cheapest" way I get this connected is via a breadboard and some jumper wires - but this costs about £2 at the moment (because I'm using upmarket breadboards!) but the main problem is anchoring it to an uncased RPi (Because who'd want to waste money on a case!)
But, if I could get hold of a "cheap" 26 way connector then I could manufacture these for a total cost of say 99p and that would be "cheap"
And I could make other things as Traffic Light LED arrays or an electronic die
And they could just plug into my RPi
So in answer to the question - "cheap" would be <50p if possible.
Thanks for the links BTW
regards
Simon
@grumpymike
Our posts crossed at same time.
I'd prob fork out for 10 to start with
Simon
Simon
Buy them in 1000 off qty or more then you can get that sort of price.
Look at making PCBs in large panels and different connectors, do a LOT of research on suitable connectors on a LOT of sites, and even look at stackable connectors to make a 26 way connector.
50p target is only really possible in large quantities.
Eureka!
http://www.tandyonline.co.uk/26-way-pcb-straight-female-header-2-54mm-pitch.html
19p over budget but a good start
Simon
Simon
Now we are talking turkey
How low can we go
Simon
How low can we go
Simon
You're not trying hard enough
How about 26p each?
http://www.ebay.co.uk/itm/20pc-Pin-Female-Header-Dual-2-54x2-54mm-H-8-5mm-Right-Angle-90-2x13p-2x13-26p-/130828432575?pt=LH_DefaultDomain_0&hash=item1e75fb74bf
How about 26p each?
Now we are cooking on gas
Simon
PS Feedback rating not fantastic though
Simon
simplesi wrote:PS Feedback rating not fantastic though
Smiles cost extra
neilf wrote:You're not trying hard enough
How about 26p each?
You forgot $6 shipping
Lost track of the best buy.
I'd buy single row headers and place them side by side.
http://www.ebay.co.uk/itm/5-pcs-Single- ... 1157387094
10 to 15 13-pin headers (how good are your snaps) to give 5 to 7 headers for £1.72 (P&P included).
Why not use these: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=330863957616
They fit exactly over a pin header on the Pi and when you cut them in half you can solder the cut off end to any board you like.
Let's see: you get 40 wires, cut them in half so that makes 80, then divide by three (quantity for one product) so you can make 26 products (with two wires to spare for emergencies).
The wires cost $2.84, divided by 26 makes $0.11 per board. I don't know how many 'p' that is, but probably less
joan wrote:Lost track of the best buy.
Better value
http://www.ebay.co.uk/itm/40Pin-40-pin- ... 0762027956
The ribbon cable idea doesn't meet the spec I'm afraid
And I realise you can get anything cheap if prepared to await the slow boat from China
Simon
Simon
Smiles cost extra
You've changed the link!
Right angle is not in spec either
Simon
By the way, the slow boat to China is now air freight. My stuff typically has taken less than 14 days (order to receipt). Depends on when the carrier has space on the plane.
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
@rattus
Its no good being cheap but not having stock
Simon
Simon
How about these :
http://www.ebay.co.uk/itm/140827538807
OK, they are in Thailand, but the price is good - 18pence each including postage, for 20 off.
Texy
Texy
"!.8inch TFT LCD + Switch Shield" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=59&t=40674
50p goes to the Foundation
- Moderator
Price is excellent
Delivery time - not so good
- not even 1 month - just a whenever
Last time I ordered something on those terms was back in November and still waiting for them to be delivered !
Simon
Simon
simplesi wrote:Price is excellent
Delivery time - not so good- not even 1 month - just a whenever
Simon
Go for it! The price is excellent.
I've only failed to receive 1 (ONE) package from Asia (value £3.16). The eBay seller returned my money without quibble once I complained. The other items from that order arrived OK.
I ordered those thaishop ones on the 13th, and they arrived a couple of days ago. Seem reasonable enough quality, too, though I haven't used them yet...
note: I may or may not know what I'm talking about...
toxibunny wrote:I ordered those thaishop ones on the 13th, and they arrived a couple of days ago. Seem reasonable enough quality, too, though I haven't used them yet...
I also have an order on the way from thaishop - could you please measure the height of the body for me?
Cheers,
Texy
- Moderator
