GPIO button press image display
by danieljay » Wed Feb 20, 2013 6:04 pm
Hey all, so i am trying to load an image file when a button is pressed connected to GPIO pins.
I followed the setup on adafruits site here: http://learn.adafruit.com/adafruits-ras ... gpio-setup
i then created my code below an its giving me an error that it cannot find a module named "Image". Very new to linux and python so all help appreciated.
#!/usr/bin/env python
import RPi.GPIO as GPIO
import time
import os
import Image
im=Image.open("/home/pi/imagejpg/Home.jpg").convert("RGB")
#adjust for where your switch is connected
buttonPin = 23
GPIO.setmode(GPIO.BCM)
GPIO.setup(buttonPin,GPIO.IN)
while True:
     if ( GPIO.input(23) == False ):
         im.show()
by davef21370 » Wed Feb 20, 2013 6:09 pm
Try...
from PIL import Image
Dave.
/uk/lancashire/heapey/dave
by danieljay » Wed Feb 20, 2013 6:22 pm
it said no module named "PIL".
I am very new and not sure if I need to install libraries(?) or other dependencies.
by croston » Wed Feb 20, 2013 6:31 pm
To install PIL:
$ sudo apt-get install python-imaging
Apologies if that's not quite right - I am working from memory as I am not at a computer at the moment!
by danieljay » Wed Feb 20, 2013 6:40 pm
before I attempt, should a simple import Image work with my current setup?
by davef21370 » Wed Feb 20, 2013 6:51 pm
Go with croston's post and you should be good.
Dave.
by danieljay » Wed Feb 20, 2013 7:09 pm
thank you all for being so helpful. the error is gone, but a new error popped up:
SyntaxError: Non-ASCII character '\xc2' in file buttonimage.py on line 13, but no encoding declared; see http://www.python.org/peps/pep-0263.html for details
tried from PIL import Image and just import Image but same error.
by croston » Wed Feb 20, 2013 7:13 pm
Is buttonimage.py your program? If so, delete and rewrite line 13 - you have done a copy & paste of a strange whitespace character. I don't think the error is anything to do with PIL.
by danieljay » Wed Feb 20, 2013 8:19 pm
Great! that solvesd that error. but now when my code is executed in terminal, i.e.
sudo python buttonimage.py, it seems to hang without any results.
i tested a simple sketch to load an image and made it executable with chmod +x like so:
import Image
im = Image.open("/home/pi/imagejpg/Home.jpg").convert("RGB")
im.show()
by danieljay » Wed Feb 20, 2013 10:22 pm
So I I added the feh image viewer since i read img.show is reliant on xv. im stilll not getting an image shown though
import Image
img=Image.open("/home/pi/Home.jpg")
img.show(command='feh')
by texy » Thu Feb 21, 2013 7:51 am
I would make sure your button is working as expected before worrying about the image. Take a look at the Mapi magazine, issue 2.
http://issuu.com/themagpi/docs/the_magpi_issue_2_final
Texy
"!.8inch TFT LCD + Switch Shield" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=59&t=40674
50p goes to the Foundation ;-)
Moderator
by danieljay » Thu Feb 21, 2013 7:58 am
The order in which to work on the two different parts of my code is irrelevant.
by texy » Thu Feb 21, 2013 9:05 am
it may well be irrelevant, but thats the order I would do things if I didn't know what I was doing ;)
You can very easily remove any reference to checking the input pin from your code to make sure the image is loaded without any pre-condition.
So as I said, making sure the button hardware is correctly working and the software is configured to match that hardware is more difficult if you have little experience of doing it.
Texy
Moderator
