Delete instance from list?
by davef21370 » Tue Feb 05, 2013 2:01 pm
I have a list of classes to do some simple scoring animation in a game. When the player picks up a bonus I append a new instance of my animation class to the list, while the animation is running the function returns True, when it has finished it returns False, at this point I need to delete the instance and remove it from the list.
At the moment I have...(excuse the indentation, it's fine in the code, b****y iPad)
for a in ascore:
if a.anim == False:
a = None
But after quitting the program and typing 'print ascore' I still get a list of references to all the instances created.
I also had...
a.remove()
to remove the instance from the list but that threw a spanner in the works, something to do with doing it while still looping through the list.
Basically, how do I remove an item from a list while still being able to loop through the list and how do I delete an instance of a class?
Thanks in advance.
Dave.
/uk/lancashire/heapey/dave
by alexeames » Tue Feb 05, 2013 2:33 pm
Would it be any use to copy the list and iterate through the copy, whilst performing changes on the original?
(I'm sure you know this, but...)
newlist = oldlist[:]
My Pi uses 2 watts - what what? ---- HiRes early production Pi photos RS Front Back | Farnell Front Back
by davef21370 » Tue Feb 05, 2013 3:14 pm
I hadn't actually thought of that, cheers.
I may iterate through the list and build a new list using only the instances that return True then copy the new list back to the original.
There must be a more elegant solution but that'll work for now.
Thanks.
by Sleep Mode zZ » Tue Feb 05, 2013 4:25 pm
When I make a google search to find a solution to a prgramming problem, most often the solution is on a page on stackoverflow.com. To this particular problem a more elegant solution might be found on this page: http://stackoverflow.com/questions/1207406/remove-items-from-a-list-while-iterating-in-python.
by rurwin » Tue Feb 05, 2013 4:34 pm
ascore = filter(lambda a: a.anim, ascore)
filter(x, y) returns a list consisting of those members of list y for which the function x returns True.
The function you want would be:
def f(a):
    a.anim == True
But since you only want it once, you don't have to make it a separate definition; that's what lambdas are for. And you should never compare with True, that is redundant and inefficient. So function x is just "lambda a: a.anim"
You pass in list ascore, and filter returns a new list ascore with only those members for which the anim attribute is True.
Edit: and in line with that StackOverflow code, it may or may not be more correct to do:
ascore[:] = filter(lambda a: a.anim, ascore)
depending on how you expect references to work:
x = ascore
# x and ascore are now different lists.
or
x = ascore
# both x and ascore are now the new list
Moderator
by timhoffman » Tue Feb 05, 2013 10:56 pm
Hi
A couple of things, just saying a=None does nothing to the instance it just rebinds the name 'a' to None.
Also the list still holds a reference.
Are you only removing some of the items in the list or everything ?
Normally deleting items from a list whilst iterating over it is probably not a good idea. Maybe consider a different approach.
If you can process the list in reverse order the you could do the following.
for i in some_list[-1::-1]:
    # do something with i
    some_list.pop()
This code iterates over the list in reverse order, and pops the last item from the list on each iteration.
May be a dictionary might be a more appropriate container, or if you need order maintained an OrderedDict, which will allow you to remove items by key rather than by index.
T
by IanH » Wed Feb 06, 2013 8:28 am
If you're finding lambda-expressions are hard to read, you could use a list comprehension, thus:
alist = [ a for a in alist if a.anim ]
Note you could also write 'if (a.anim==True)', instead of 'if a.anim', but it's not necessary.
https://github.com/IanHarvey <-- Pi stuff
