Why is Raspbian in runlevel 2 by default
by DaSt1986 » Tue Feb 05, 2013 11:13 am
Although I'm not the guru I want to be yet, I'm getting more and more advanced in Linux each day by using my Raspberry PI. Today I learned about runlevels, and I'm curious why the default setting of Raspbian is to start in runlevel 2 instead of runlevel 3 (which is the Debian default as far as I know). Although I haven't tried it yet, I know I can just edit the inittab and set runleven 3 as default, I want to know why Raspbian chose to use runlevel 2 by default.
Anyone here who can tell me that?
Kind regards,
Daryl
by rurwin » Tue Feb 05, 2013 11:26 am
Runlevel 2 has always been the default for text-mode so far as I was aware, but then I've generally stayed away from them since SunOS.
http://www.debianhelp.co.uk/runlevels.htm says that 2 is the Debian default, but that other distros use 3.
Moderator
by remsnet » Tue Feb 05, 2013 11:29 am
DaSt1986 wrote:Hi,
Kind regards,
Daryl
Daryl,
That may so since an PI been an Thin Client.
Just change the default runlevel if you require it.
regards
by DaSt1986 » Tue Feb 05, 2013 11:30 am
remsnet wrote:
DaSt1986 wrote:Hi,
Kind regards,
Daryl
Daryl,
regards
Had nothing to do with requiring it, just wondering and learing.
Thanks everybody!
by rpdom » Tue Feb 05, 2013 3:14 pm
Debian doesn't use the run levels to the extent that many other *ix systems do. By default it always boots into runlevel 2 (Yes, I am talking about the official Debian systems as well as Raspbian. Raspbian is pretty much a normal Debian system, just compiled to run best on the Raspi and with a few extra packages specifically for the Pi.
Other systems may use runlevel 2 as text-mode multi-user, 3 as text-mode multi-user with network, 5 as GUI mode etc, but Debian treats 2, 3, 4 and 5 as identical.
Levels 0, S, 1 and 6 have their normal functions (shutdown, single-user, maintenance and reboot)
