No power no LED nothing
by adamtlee87 » Tue Jan 29, 2013 10:38 pm
I have had my raspberry pi for a short while now. I have tested it and everything was working fine. Today i went to turn on the raspberry pi and nothing happened. No power no led indicators nothing. It is the same usb port same chord. I have changed nothing. Does anyone have any idea what is going on?
by HTNoBrakes » Tue Jan 29, 2013 10:52 pm
I had same issue and it was simply a loose SD card. If you hadn't already checked, try reseating it.
by pluggy » Tue Jan 29, 2013 10:56 pm
Power supply given up the ghost ?
by drgeoff » Wed Jan 30, 2013 12:19 am
HTNoBrakes wrote:I had same issue and it was simply a loose SD card. If you hadn't already checked, try reseating it.
Even with a loose SD card the red PWR LED should be lit.
by drgeoff » Wed Jan 30, 2013 12:22 am
pluggy wrote:Power supply given up the ghost ?
Or the cable. The build quality of some is quite dire.
by adamtlee87 » Wed Jan 30, 2013 2:03 am
I tried two separate chords neither worked. Both i have tried previously and both have worked previously. The sd card is secure and in place. I am at a loss. :cry:
by drgeoff » Wed Jan 30, 2013 12:28 pm
You haven't confirmed that the PSU is not dead.
by obcd » Wed Jan 30, 2013 12:49 pm
It could also be that the micro usb connector got damaged somehow. They look pretty fragile.
I assume TP1 - TP2 voltage will be 0V :(
by adamtlee87 » Thu Jan 31, 2013 9:21 am
i will check tp1 & 2 as soon as i can and report back with my findings.
