Hi All
I'm trying to install Open Office but it keeps bombing out. I get a message relating to being out of space. When I try to reboot, it hangs. I then have to reinstall the OS (Wheezy) image on the SD card and start over.
I have a 16GB SD card, although for some reason I don't understand, the OS appears to be on a partition size of 1.8GB.
Any suggestions?
Open Office
When you first image the SD card, it won't be using the whole of the SD card (just the size of the image). Use Raspi config to expand the partition to fill up the whole SD card. Then LIbre/OpenOffice should fit.
James
James
- Moderator
Hi James
Thanks for the reply. I was wondering if that was what I needed to do! The Wheezy start-up screen gives the option to expand the filesystem.
I'll try it and post my results!
-Mike
-Mike
That was the problem. Installed just fine without a problem!
I also see the full 16Gb of my SD card in the file manager also.
Thanks.
Thanks.
