Last friday I've received my Raspberry, together with a USB adaptor from RS, yeah!!!! So today was time to play around with it!
After placing the latest image (http://downloads.raspberrypi.org/images/raspbian/2012-12-16-wheezy-raspbian/2012-12-16-wheezy-raspbian.zip) on my class 2 SD card (4GB) it's was time to give it a try. Everything went fine, but after connecting my Pi to a network cable I had a network connection for not more than 5 minutes
After activating SSH and hooking the Pi up to the network cable without a screen or a USB keyboard the result was the same, within 5 minutes no more network connection...
To be shure that losing my network connection has something to do with the image I installed the Occidentalis image (http://learn.adafruit.com/adafruit-raspberry-pi-educational-linux-distro/occidentalis-v0-dot-2) from Adafruit on my SD card. From now on I didn't need to hook up any USB devices and had SSH access out-of-the box. So far, so good... After starting the Pi up the issue is the same
The only thing that I do is running a ping so see if the Pi is up-and-running and try to find some updates using sudo apt-get update and sudo apt-get upgrade. Due to the fact that my Pi loses it network connection so quick I can't even to an upgrade...
When checking the voltage that runs over P1 and P2 I'm getting values between 4,92V and 5,02V. For what I see on other fora this seems to be normal when hooking up a power supply of 5V. I'm using this power supply: http://raspberrypi.rsdelivers.com/product/rs/hnp06-microusb/micro-usb-euro-power-supply-for-raspberry-pi/7263053.aspx
Does anyone have any idea if this issue is a software or a hardware problem? Or, even better, knows a solution for this issue? It feels it's time to contact with RS and dive into the RMA procedure?
Thank you for your reaction!
