There is some discussion about the rationale for this in another thread. I started posting technical stuff there and realized that posting here would be more useful.
Outside of the why, which belongs in that thread, I want to talk about the how.
I see that Samba is in the repository, so I wanted to give it a shot.
The packages I am installing thus far are:
krb5-config, libkrb5-3, ntp, ntpdate, samba and winbind
There's 58 other packages that go with it, but doing sudo apt-get install and these six will get you started.
Today, I discovered that using an emulated Pi has some disadvantages. Namely, without a TAP connection, the virtual pi is not able to communicate correctly with the NTP server or the domain controller.
Outside of that, kerebos5 compiles just fine and I can configure it. Samba and Winbind also compile. For the curious, I discovered that Samba4 fails during configuration, but not during compiling. Because Samba4 doesn't configure correctly, winbind4 doesn't properly install.
Again, I think Samba4 didn't configure because of the communication issues.
More work to come next week. Next week, there will be more technical details and links to screenshots.
Active Directory and RPis
I have since discovered that Samba4 will attempt to auto-configure a connection to Active Directory if it is present.
I still have trouble creating a Bridged Connection in QEMU, but a colleague has procured a physical Raspberry Pi for use. There is interest throughout the school district in them, so he is bringing me one soon.
When I get the physical RPi in my hands, I will let everyone know if Samba4 works as I think it will.
As an aside, I use the 3D printed case as a means to promote the RPi. People are amazed at the size of it.
I think the QEMU Software (http://sourceforge.net/projects/rpiqemuwindows/) that was posted on this site has great potential. I installed and tested the software. The install files are very easy to use.
