I know this has been posted before, and apologies for starting a new thread for it but i need help.
I got my pi from RS today and broke it within 5 seconds.
As I placed the pi in the clear case I snapped the card holder on the right hand side and now the SD card doesn't stay in place, it pops out.
Please help.
broken sd slot
We really should get this written up in the wiki so we can just post a link
There's this thread http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=28041&p=248969&hilit=broken+sd+slot#p248969 keep checking back I'll add a cople of more links as I find them.
There's another thread it includes the following link it's one of the best documented fixes.
http://raspi.tv/2012/how-to-fix-a-broken-sd-card-slot-on-your-raspberry-pi
This is the thread if your interested
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=63&t=26876&p=241614&hilit=broken+sd+slot#p241614
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek
If you find a solution please post it in the wiki the forum dies too quick
Epoxy glue the broken part back on and strengthen with a postage stamp size piece of plastic across the three sides of the slot?
Thats about the jist of the raspi.tv fix but with additional pictures
It's a cool bit of documentation.
Thanks for the help. Will give it a try.
I'll post a photo of the damage if I get time.
i've just had a chance to look at the repairs noted, many thanks, the Credit card fix seems to be the way to go, also will look good with the Holigram left as the repair patch.
i do have another question, has anybody tried to glue a micro sd card adapter in place?
Thanks again for the help guys.
I've suggested this in the past the only downside is your limintation to slightly more expensive (It's not a lot more expensive by the way) micro SD cards.
I have at least half a dozen micro sd's from recent phones so will not be an issue.
I hope the credit card approach works for you - it didn't for me so I replaced the card holder. I've done two now - it's not all that difficult if you can solder - there are pictures and a description here.
exartemarte wrote:I hope the credit card approach works for you - it didn't for me so I replaced the card holder. I've done two now - it's not all that difficult if you can solder - there are pictures and a description here.
Thanks for the info, I haven't soldered in over 20 years, so don't want to try such job without some practice, I'll try the credit card approach whilst I order another (Not from rs, not happy you can't talk to anyone ) then buy the components and take it to the local phone repair see what they can do.
This cheap option might stop you breaking it again.
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=40&t=31609
My slot was broken too. I just replaced it with one I could cheaply get off ebay: http://www.pieter-jan.com/node/12
