Hi Folks,
I tried to ask this question one week ago, but there was only trash. So I try again now and ask you for serious answers.
I tried to configure Wifi without x. If I do so it won't work, unless I start an x session. There a can see the right settings and I only need to press connect. Wifi connects and works. Even on a reboot it still works. So I took all setting in /etc/network/interfaces and in etc/wpa_supplicant/wpa_supplicant.conf in put them in my config. With this settings, wlan0 did not come up un start, I have to start it from the wpa_gui!
What's wrong here, what am I missing?
Thanks for help,
Thomas
Wifi without x, next try
When to boot up to the CLI and the wireless is down, then can you get to it and type in "sudo ifconfig"
My ethernet only shows
What is shown on yours ?
Also does the wifi device show up in "lsusb" ?
- Code: Select all
root@raspberrypi:/home/pi# ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:19:d7:61
inet addr:192.168.0.5 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:85655 errors:0 dropped:256 overruns:0 frame:0
TX packets:2374 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5515386 (5.2 MiB) TX bytes:219875 (214.7 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Pi1 (Nov 2012 loft)= 1KW immersion controller for Solar panel
Pi2 (Jan 2013 living room)=Play thing
Pi3 (Feb 2013 mobile)= Play thing with Tandy Ladder board,breakout board,Nokia display
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=28193
......maybe try WICD http://wicd.sourceforge.net it is in the repository
I know everything about nothing"
I too had loads of problems getting wifi working. In the end I just went through the following (if the page asks for a password just click on Cancel):
http://blog.xrmx.co.uk/2012/07/setting- ... on-wheezy/
My problem is, that I don't like to use additional SW to get it working.
After setting Wifi up from my scripts, /etc/network/interfases look like this;
That's the same for Wifi if I use wpa_gui as far as I know.
An the /etc/wpa_supplicant/wpa_supplicant.conf looks like this:
That's also the same for Wifi if I use wpa_gui as far as I know.
If I don't use the wpa_gui ifconfig shown this after a boot:
No IP address assigned for wlan0.
After connection manually with wpa_gui Ifconfig gives this:
As you see it's connected and I get an IP. I only don't like to swich to the wpa_gui. how can I activate wlan0 without wpa_gui?
- Code: Select all
nano /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them.
# The loopback network interface
auto lo
iface lo inet loopback
# The WLAN network interface
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
# The LAN network interface
auto eth0
iface eth0 inet dhcp
- Code: Select all
update_config=1
network={
ssid="BlabberBlub06"
psk="xxxxx"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
group=TKIP WEP104 WEP40
auth_alg=OPEN
- Code: Select all
eth0 Link encap:Ethernet HWaddr b8:27:eb:7d:0f:d0
inet addr:192.168.2.75 Bcast:192.168.2.255 Mask:255.255.255.0
RX packets:179 errors:0 dropped:0 overruns:0 frame:0
TX packets:148 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:18599 (18.1 KiB) TX bytes:23355 (22.8 KiB)
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:100 (100.0 B) TX bytes:100 (100.0 B)
wlan0 Link encap:Ethernet HWaddr 80:1f:02:76:50:f6
UP BROADCAST MULTICAST MTU:1500 Metric:1
- Code: Select all
RX packets:1183 errors:0 dropped:0 overruns:0 frame:0
TX packets:269 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:87751 (85.6 KiB) TX bytes:45668 (44.5 KiB)
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:200 (200.0 B) TX bytes:200 (200.0 B)
inet addr:192.168.2.13 Bcast:192.168.2.255 Mask:255.255.255.0
RX packets:342 errors:0 dropped:367 overruns:0 frame:0
TX packets:28 errors:0 dropped:1 overruns:0 carrier:0
RX bytes:86994 (84.9 KiB) TX bytes:6053 (5.9 KiB)
truehl
http://www.squeezeplug.de
I actually believe it may be feasible to run wpa_supplicant from command line, bottom of this page:
http://hostap.epitest.fi/gitweb/gitweb. ... ant/README
