- Code: Select all
w /sys/block/mmcblk0/queue/scheduler - - - - deadline
I hope SD IO performance will be much better now. But in my opinion this setting should be guaranteed since pure installation.
w /sys/block/mmcblk0/queue/scheduler - - - - deadlineecho "deadline" > /sys/block/mmcblk0/queue/scheduler
# dd if=/dev/zero of=test bs=1M count=512
536870912 bytes (537 MB) copied, 34.6949 s, 15.5 MB/s
# echo "noop" > /sys/block/mmcblk0/queue/scheduler
536870912 bytes (537 MB) copied, 35.3581 s, 15.2 MB/sroot:~# echo "deadline" > /sys/block/mmcblk0/queue/scheduler
root:~# sync
root:~# dd if=/dev/zero of=test bs=1M count=128
128+0 records in
128+0 records out
134217728 bytes (134 MB) copied, 14.0027 s, 9.6 MB/s
root:~# sync
root:~# echo "noop" > /sys/block/mmcblk0/queue/scheduler
root:~# sync
128+0 records in
128+0 records out
134217728 bytes (134 MB) copied, 13.1649 s, 10.2 MB/s
