Running 12v portable DVD player and pi on same power source
by cainy393 » Sun Jan 13, 2013 9:39 am
I have a potable DVD player which I have hooked up to my pi to use as a screen/casing.
What's the best way to power this 12v/1.25A DVD player and my pi from the same power lead or rechargeable battery?
by madzieph » Sun Jan 13, 2013 10:04 am
I guess the best way to power that setup is to get a power supply that can deliver both 12V and 5V rails. By any chance, if you have an old usb-to-ide enclosure for 3.5in hdds you'll be in luck because the power supply that comes with it has both. Or you can DIY an old pc power supply to serve the purpose.
by cainy393 » Sun Jan 13, 2013 11:34 am
Unfortunately I don't think I have anything like that. Any idea where I might find one?
by madzieph » Sun Jan 13, 2013 12:15 pm
by mahjongg » Sun Jan 13, 2013 12:58 pm
Cigar plug 12V to 5V converter with USB output connector.
Can cheaply (less than $5) be bought anywhere, and is a fine PSU for a PI.
Tip of the plug is +12V input.
Moderator
