My Bramble is up and running!
by diereinegier » Fri Jan 11, 2013 11:11 pm
Today I got my little cluster of 4 Raspberries up and running and gave some MPI programs a go:
georg@crumb0 /net/crumb0/home/georg/src/mpitutorial $ time ./apple_serial 4096
RE_START =                                       -2
RE_STOP  =                                        2
IM_START =                                        0
IM_STOP  =                                        2
XPIX     =                                     2048
YPIX     =                                     1024
MAXITER  =                                     4096
    1023
real    1m2.730s
user    1m1.910s
sys     0m0.250s
georg@crumb0 /net/crumb0/home/georg/src/mpitutorial $ time mpiexec -H crumb0,crumb1,crumb2,crumb3  apple_mpi_nblock.2 4096
RE_START =                                       -2
RE_STOP  =                                        2
IM_START =                                        0
IM_STOP  =                                        2
XPIX     =                                     2048
YPIX     =                                     1024
MAXITER  =                                     4096
MPI_Wtime is global
real    0m18.129s
user    0m16.790s
sys     0m0.840s
For this particular case there is nearly perfect scaling: one node takes 63 seconds to compute while four nodes need about 18 seconds.
Check out my MPI tutorial at https://github.com/GeorgBisseling/MPI-Tutorial/blob/master/tutorial.pdf?raw=true with full source code at https://github.com/GeorgBisseling/MPI-Tutorial/blob/master/mpitutorial.tar.gz?raw=true.
[mod edit: Links changed at the request of the OP]
DISCLAIMER: If you want to do fast computations, then do not even consider the Raspberry Pi! Clustering them is just done for fun and to learn about the problems and pitfalls of distributed memory computing.You couldn't do that with lower energy and space requirements, I guess.
Download my repositories at https://github.com/GeorgBisseling
by diereinegier » Sat Jan 12, 2013 1:58 pm
The box is stackable and contains not only the raspberries (lower right) but the power supplies (upper left), a 7-port USB-Hub (lower left) and a 5-port Ethernet-Switch (upper right).
Only a 230V power chord and a network cable leave the box.
by diereinegier » Thu Jan 24, 2013 2:05 pm
I took a nbody sample code http://www.ids.ias.edu/~piet/act/comp/algorithms/starter/index.html and parallelized it using MPI.
Making this scale over 4 Raspberries was much harder than for a Mandelbrodt code or cpi.c.
For say 50 bodies the serial program was still faster than the parallel one. I tried again for 1000 bodies.
Serial short of 42 minutes, parallel on 4 nodes short of 15 minutes. This is by no means perfect, but acceptable. I must recheck for about 100 bodies, because 1000 bodies are computed so slowly regardless of the number of Raspberries involved.
The reason is for a start that 100Mbit Ethernet is too slow and evenmore that handling the network causes far too much CPU load on the Raspberry. For the program parts that have linear computational complexity in n I do not even think of parallelizing because computing the values is faster than getting them from the other nodes. Only the computation of acceleration, jerk, potential energy and collision time estimation is parallelized. If anyone is interested I will post the code.
by Lob0426 » Thu Jan 24, 2013 9:03 pm
diereinegier wrote:Image
The pictures are not showing in this post.
RS rewards Europe customers for long wait with old stock also
(RS)Allied ships old stock to reward U.S. Customers for long wait!
http://rich1.dyndns.tv/?page_id=71
by diereinegier » Thu Jan 24, 2013 10:40 pm
For me they show in Opera, Firefox and Chrome.
What Browser do you use?
by diereinegier » Fri Jan 25, 2013 8:33 am
Some scaling measurements. Enjoy!
Scaling of nbody_mpi
by diereinegier » Sat Jan 26, 2013 4:06 pm
The combined original sources and the parallelized one:
nbody_mpi_2013-01-26.tar.gz
Enjoy!
(12.4 KiB) Downloaded 13 times
by diereinegier » Sat Jan 26, 2013 10:46 pm
diereinegier wrote:Some scaling measurements. Enjoy!
Unfortunately there was a typo in the spread sheet: runtime for 1000 bodies on 4 nodes was too good to be true.
corrected version
by diereinegier » Sat Jan 26, 2013 10:55 pm
The integration scheme used in this code is called Hermite Integration and I did not quite get the point compared to other methods. The algorithm seems to be very involved. I guess that something simpler like leapfrog with softening would better fit the Raspberries.
Maybe I will come up with a simpler integration algorithm.
Meanwhile consult the fine material presented here:
http://www.artcompsci.org/kali/development.html
If you like to play around with some bigger systems on your quad core windows desktop machine I ported some of the Kali code to a C# project targeted to the cost-free Visual Studio Express 2012 (or the bigger versions of course). Some time critical computations were moved back to C:
https://github.com/GeorgBisseling/nbodysketch
That even contains a very simple player to watch your simulation in motion.
by diereinegier » Wed Jan 30, 2013 8:41 pm
I published the code on GitHub:
https://github.com/GeorgBisseling/nbody_mpi
by diereinegier » Fri Feb 08, 2013 9:19 pm
I was not entirely happy with my cluster setup: the thick and stiff Ethernet cables exerted very much of a force onto the raspberries and the USB hub together with all the very long cables just to bring the juice seemed a little overdone.
I found some nice flat Ethernet cables that do not cause errors or retransmissions at 100 Mbit.
Then I cut two USB-A-to-USB-A cables, got rid off shielding an data wires and connected them to the hub's PSU. Of course after having tested that "back powering" is stable even when overclocking to 900 MHz.
The result is much less of a mess. Even the camera had an easier time to focus, or so it seems.
Clean Room
by diereinegier » Sat Feb 23, 2013 10:51 pm
OMG, mentioning the MPI tutorial resulted in so much web traffic on my home page that I had to pay extra fees!
Nice to see that so many people are interested in MPI on the RasPi.
But - must - get - better - contract!
Please use this URL if you can:
