Reach raspberry by name instead by IP address
by GianfrancoPa » Wed Jan 09, 2013 7:18 am
Another question today...
I have installed a webserver on my raspberry that i can reach using his IP number, for example:
http://192.168.2.30
is possibile to do this?
http://myrasp-name/
Thanks you!!!
by Joe Schmoe » Wed Jan 09, 2013 7:31 am
Some say yes, some say no.
Some say that you can put something in one of the dhcp config files to cause the Pi to "export" a name to the local LAN.
Some say that there is this thing called "Zero Conf" that automagically makes everything work (and makes your breath smell sweet and your shoes to shine).
But none of this has ever worked for me.
by GianfrancoPa » Wed Jan 09, 2013 7:44 am
If I read my router dhcp list, i see that my device uses a name "raspberrypi", but if I do http://raspberrypi/ on my browser, I retrieve error page. It's your same situation???
Zero Conf is the utility of raspbian wheezy where is possible to set many options?
by RaTTuS » Wed Jan 09, 2013 7:44 am
put the name in the place where your dhcp server is
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by Joe Schmoe » Wed Jan 09, 2013 8:11 am
GianfrancoPa wrote:If I read my router dhcp list, i see that my device uses a name "raspberrypi", but if I do http://raspberrypi/ on my browser, I retrieve error page. It's your same situation???
Yes. As you report, it shows up in my router DHCP table, but any attempts to use this name from other machines on the LAN (e.g., "ping raspberrypi") fail.
It could be a function of how good your router is - that some routers do indeed "publish" these names (the ones that show up in the DHCP table), but others (most), like yours & mine, do not.
I guess. I know nothing about it. Some other posters, who were making a big to-do about it in another thread, will no doubt be posting on this thread soon.
I'm skeptical of anything that has the word "zero" in it...
by GianfrancoPa » Wed Jan 09, 2013 8:15 am
Joe Schmoe wrote:
GianfrancoPa wrote:It could be a function of how good your router is - that some routers do indeed "publish" these names (the ones that show up in the DHCP table), but others (most), like yours & mine, do not.
Uhm, in my lan there are two devices that I can reach correctly using their names, like my NAS....
by pluggy » Wed Jan 09, 2013 12:31 pm
The easiest way is to put the name and IP address in the hosts file on the client machine. Even Windows has one.
http://www.howtogeek.com/howto/27350/be ... osts-file/
If your router isn't doing the business, you'd otherwise need extra software on the Pi.
by rurwin » Wed Jan 09, 2013 1:03 pm
I agree. Unless you have a lot of PCs, then using the hosts files is the way to go.
Just make the IP addresses of all computers static and add the names and addresses to the hosts file of every computer.
Unlike the hostnames, static IP addresses are supported by almost every router on the market and it is easy to set up. Easier than doing it on Windows or Linux, and those are fairly trivial.
On Linux the hosts file is /etc/hosts and on Windows it is /windows/system32/drivers/etc/hosts. Both files have the same format.
If your router doesn't support static addresses, we'll tell you how to set the address in Linux or Windows, but of course then you'll have issues if you take your Pi or PC around to a mate's house.
Moderator
by efflandt » Thu Jan 10, 2013 12:42 am
Zeroconfig not actually rocket science or something mystic, it is a local broadcast name resolution somewhat similar to Windows file/printer sharing (samba in Linux). It is included in Apple computers, Bonjour from Apple can be installed in Windows to do it, and in Linux it is known as avahi. Of course it works best if each hostname is unique, so I set unique hostname in /etc/hostname and /etc/hosts of the SD card for each Pi. I use those names to ssh to each Pi, even if its dynamic IP changes.
While DNS might still not find computers on the LAN by name, applications can by the hostname followed by .local. Following were after doing sudo apt-get install avahi-daemon on a Pi.
From Windows 7 with Bonjour installed:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\efflandt>nslookup raspberrypi.local
Server:  dsldevice.domain_not_set.invalid
Address:  172.16.0.254
*** dsldevice.domain_not_set.invalid can't find raspberrypi.local: Non-existent
domain
C:\Users\efflandt>ping raspberrypi.local
Pinging raspberrypi.local [172.16.0.102] with 32 bytes of data:
Reply from 172.16.0.102: bytes=32 time=69ms TTL=64
Reply from 172.16.0.102: bytes=32 time=19ms TTL=64
Reply from 172.16.0.102: bytes=32 time=15ms TTL=64
Reply from 172.16.0.102: bytes=32 time=29ms TTL=64
Ping statistics for 172.16.0.102:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 15ms, Maximum = 69ms, Average = 33ms
From Ubuntu 12.04 Linux on a PC (avahi was installed by default):
efflandt@XPS8100-1204:~$ host raspberrypi.local
host: '.local' is not in legal name syntax (empty label)
efflandt@XPS8100-1204:~$ ping -c2 raspberrypi.local
PING raspberrypi.local (172.16.0.102) 56(84) bytes of data.
64 bytes from raspberrypi.domain_not_set.invalid (172.16.0.102): icmp_req=1 ttl=64 time=13.6 ms
64 bytes from raspberrypi.domain_not_set.invalid (172.16.0.102): icmp_req=2 ttl=64 time=8.56 ms
--- raspberrypi.local ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 8.560/11.082/13.604/2.522 ms
efflandt@XPS8100-1204:~$ avahi-browse -at
+  wlan0 IPv6 XPS8100-1204 [78:e4:00:26:b8:ac]              Workstation          local
+  wlan0 IPv4 rpi8 [b8:27:eb:80:53:e5]                      Workstation          local
+  wlan0 IPv4 raspberrypi [00:9c:91:99:c0:29]               Workstation          local
+  wlan0 IPv4 XPS8100-1204 [78:e4:00:26:b8:ac]              Workstation          local
+  wlan0 IPv6 XPS8100-1204                                  Remote Disk Management local
+  wlan0 IPv4 rpi8                                          Remote Disk Management local
+  wlan0 IPv4 raspberrypi                                   Remote Disk Management local
+  wlan0 IPv4 XPS8100-1204                                  Remote Disk Management local
avahi-browse is included in avahi-utils package (which you can also install on Pi)
by Twinkletoes » Thu Jan 10, 2013 12:53 am
zero conf / avahi / bonjour (all names for the same thing) also handles name conflicts - if you call three R-Pis by the same name "raspberry", you'll see the following network names:
raspberry
raspberry-1
raspberry-2
For lots of details here's a lecture by the guy who invented it for Apple (Stuart Cheshire) - http://www.youtube.com/watch?v=kgMVjEJiHDM
by terrycarlin » Thu Jan 10, 2013 8:34 pm
When using zero conf / avahi / bonjour, the big trick is to append .local after the name.
So on your RPi that has a hostname of raspberrypi you would connect to it using raspberrypi.local
ssh pi@raspberrypi.local
http://raspberrypi.local/index.html
On raspbian, you may need to install avahi. This provides the bonjour services.
sudo apt-get install avahi-utils
Then you can do this:
 avahi-browse -a -d local
to see all of the devices that advertise zero conf / avahi / bonjour services in the .local domain.
Don't forget to append that .local to the names.
it just works. It's not fussy at all.
If it ain't broke, take it apart and see how it works.
by GianfrancoPa » Fri Jan 11, 2013 6:59 am
RaTTuS wrote:put the name in the place where your dhcp server is
raspberrypi 192.168.2.37 B8:27:EB:--:--:-- Forever
by GianfrancoPa » Fri Jan 11, 2013 7:45 am
terrycarlin wrote:When using zero conf / avahi / bonjour, the big trick is to append .local after the name.
pi@raspberrypi ~ $ avahi-browse -a -d local
+ eth0 IPv4 raspberrypi Remote Disk Management local
+ eth0 IPv4 raspberrypi [b8:27:eb:--:--:--] Workstation local
+ eth0 IPv4 Brother MFC-J430W PDL Printer local
+ eth0 IPv4 Brother MFC-J430W UNIX Printer local
+ eth0 IPv4 Brother MFC-J430W Internet Printer local
+ eth0 IPv4 Brother MFC-J430W Web Site local
If I open, from a different pc on the lan,
http://raspberrypi/
I get alway error page...
by GianfrancoPa » Fri Jan 11, 2013 9:11 pm
I followed as described here: http://elinux.org/RPi_Advanced_Setup
in this way I can reach my raspberry using on the browser http://raspberrypi.local/
On Windows may be necessary to install The Bonjour Print Service from here: http://support.apple.com/kb/DL999
Now... If I wish to change the name in myname.local???
by GianfrancoPa » Sun Jan 13, 2013 12:07 pm
GianfrancoPa wrote:Now... If I wish to change the name in myname.local???
Solved: http://simonthepiman.com/how_to_rename_ ... rry_pi.php
