wordpress and phpmyadmin slow with Raspbian “wheezy”?
by morpheus90 » Tue Jan 08, 2013 12:43 pm
Is it normal that wordpress and phpmyadmin stored on the webserver i've created inside my Raspberry Pi with Raspbian “wheezy” are slow a lot, and php pages that i've created are really fast? Are so heavy wordpress and phpmyadmin for the Raspberry Pi?
by cszone » Mon Feb 04, 2013 4:12 pm
I have same problem , I have installed Debian 6
by technion » Mon Feb 04, 2013 9:21 pm
morpheus90 wrote:Is it normal that wordpress and phpmyadmin stored on the webserver i've created inside my Raspberry Pi with Raspbian “wheezy” are slow a lot, and php pages that i've created are really fast? Are so heavy wordpress and phpmyadmin for the Raspberry Pi?
The fact that, in a forum covering "networking and servers", this seems to be the only FAQ, suggests it is not only normal, but horribly normal.
by tonyhughes » Mon Feb 04, 2013 9:33 pm
Wordpress with SQLite might be somewhat faster.
If you are not hell bent on WP, and would simply like something fast, that the Pi can handle a little better, I discovered RazorCMS through this site, and tested it, its a flat file blogging platform, super easy to install, and runs super fast on the Pi.
Instructions here: viewtopic.php?p=277606#p277606
Or install Baked Raspberry Pi Mod to do it for you.
I have also run Drupal / MySQL / Apache2 on a Pi, and while it wasn't "fast", it works just fine. I am considering moving http://www.geek101.co.nz to a Pi fulltime if I can get Drupal running a little faster, perhaps with SQLite and Lighttpd.
I am also working on speeding Wordpress up and adding it to Baked Raspberry Pi Mod too.
