In these days i'm out of home and i use an internet key for browsing.
I've bring with me the rasp and i'd like to share the internet connection with it.
This is a general network problem, not necessary related to raspberry it self.
I'd like to share the internet connection (an internet key it,s a dial up connection type, under windows) thru my ethernet cable so that rasp can use it.
I've found some tutorials about sharing the cnnection with two eth interfaces, but only using linux. In my case I need to configure a pc running windows 7 and the rasp (linux).
Without using the internet key, i can share my connection using a second router in gated mode, but this stop the internet access from my pc. The same thing with internet key is not possible in this way under windows, and i'm stucked and now the rasp has not an internet access.
I think that is not a difficult thing to do, with a pc and one router (not connected to the internet) available for experimenting. But i don't know how, and google seems to be my enemy this time
Thanks in advantage!
