I put Deluge and Deluge Web UI on it after I Canola'd youtube for idea's about how I'd go about random time killing tasks regarding torrents and a headless server. I got putty running etc. It was all going great... then Samba happened. And that's why I'm here.
I'm able to share a directory on the Host SD card without a problem. I do have to chmod it [the directory] to 775, but I can Read/Write it without a problem. The problem comes when I try to share Directories on a mounted drive. In this case, it's a 320GB WD Harddisk. I'm running it through a Powered USB Hub (I also tried with a jumpdrive hooked to the unit.) I tried to use it first as a Fat32, then as a ext4.
Here's my current fstab. I also tried to mount it under defaults. When it was a fat32, I used vfat. The partition in question is the first one on it's device. It's the sda1 in the list. I named the directory I mounted it to as sda1 since I can't remember anything... at all.
- Code: Select all
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mmcblk0p2 / ext4 defaults,noatime 0 1
/dev/sda1 /mnt/sda1 ext4 rw,auto,user 0 0
I'm pretty sure it's a problem with my Samba configuration:
- Code: Select all
[global]
workgroup = MAINFRAME
server string = %h server
dns proxy = no
log file = /var/log/samba/log.%m
max log size = 1000
syslog = 0
panic action = /usr/share/samba/panic-action %d
passdb backend = tdbsam
obey pam restrictions = yes
unix password sync = yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
pam password change = yes
map to guest = bad user
usershare allow guests = yes
security = share
;[homes]
;comment = Home Directories
;browseable = no
;read only = no
;create mask = 0775
;directory mask = 0775
;valid users = %S
[Torrents]
comment = Torrent Data
path = /mnt/sda1
read only = no
writeable = Yes
;only guest = Yes
create mask = 0777
directory mask = 0777
browseable = Yes
public = yes
[Test]
comment = Test
path = /media/test
read only = no
writeable = Yes
;only guest = Yes
create mask = 0777
browseable = Yes
public = yes
The Test share works fine. I can read/write though I did have to chmod the test folder. I chmod the other folders both manually and using a -r on chmod but all I can do is read. It's all quite infuriating.
So, what am I doing wrong?
