I downloaded firefox and seamonkey using midori on
my raspberry and when I try to run either one,
I get error "cannot execute binary file".
Have execute permission on both.
jozien17
cannot execute binary file in firefox or seamonkey
hmm... I'd say you need to use that 'sudo apt-get install' thingy instead of downloading stuff using your browser. It's probably to do with ARM or windows or something...
note: I may or may not know what I'm talking about...
toxibunny wrote:hmm... I'd say you need to use that 'sudo apt-get install' thingy instead of downloading stuff using your browser. It's probably to do with ARM or windows or something...
I tried apt-get and neither firefox or seamonkey "not found"
jozien17
I dunno then, sorry. What's wrong with midori?
I use seamonkey as my default brouser because I can check my e-mail
jozien17
jozien17
I believe Seamonkey is x86 only so it's not available for the Pi
Firefox on Raspbian is called iceweasel due to trademark issues.
sudo apt-get update
sudo apt-get install iceweasel
sudo apt-get update
For seamonkey you would have to download the source code near the bottom of http://www.seamonkey-project.org/releases/ and compile it yourself, since the compiled Linux versions are not compiled for the Pi cpu.
I'll try that because I miss not having a simple HTML editor that the old Netscape had. But it will probably take overnight to compile.
Seamonkey on Raspbian is called iceape and can be installed with apt-get.
malakai wrote:Firefox on Raspbian is called iceweasel due to trademark issues.
Interesting - I never knew that and always wondered why it was called IceWeasel. Quick trip to WIkipedia has clarified it all. Thanks.
- Moderator
efflandt wrote:For seamonkey you would have to download the source code near the bottom of http://www.seamonkey-project.org/releases/ and compile it yourself, since the compiled Linux versions are not compiled for the Pi cpu.
I will try to compile seamonkey myself because seamonley also allows me to check my e-mail.
What do I use now to check my email on pi?
Thanks to everyone for your repplies
jozien17
jozien17 wrote:I will try to compile seamonkey myself because seamonley also allows me to check my e-mail.
Thunderbird? Called icedove on Raspbian/Debian
Spot the theme?
Firefox = iceweasel
Thunderbird = icedove
Seamonkey = iceape
rpdom wrote:jozien17 wrote:I will try to compile seamonkey myself because seamonley also allows me to check my e-mail.
Spot the theme?
Firefox = iceweasel
Seamonkey = iceape
Very clever.
I downloaded and installed iceape and it works great, now I can check and send e-mail,
don't have to compile seamonkey.
Works exactly as seamonkey.
jozien17
