I am having difficulty getting my Pi to connect to the network. I have tried 2 different ethernet cables, 3 different power supplies, using dhcp and setting a static address for the pi, but still no luck. Is my Pi a bad board or what. When I use dhcp it will not get an IP address, when I assign a static address I cant ping the router. Any help is appreciated.
Pi will not connect to network
What does the ifconfig command show?
eth0
Link encap:Ethernet HWAddr b8:27:eb:5f:a4:1b
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:5 errors:0 dropped:0 overruns:0 frame:0
collisions: 0 txqueuelen:1000
RX bytes: 0 (0.0 B) TX bytes: 0 (0.0 B)
and then all the loopback info which is normal
Forget it, figured it out. Thanks though.
What was the problem?
