Problem with /sys/class/thermal/thermal_zone0/temp
by milhouse » Sat Jan 05, 2013 3:29 am
I've had this problem a few times now, over the last 2-3 months, on Raspbian.
I've found that if a script is left running that repeatedly calls "cat /sys/class/thermal/thermal_zone0/temp", eventually the script will hang while trying to read the temperature data. On a number of occasions I've had this happen after 2-3 days (reading the temp value every 2 seconds). The only solution is a reboot. Each time, the "hang" has been caused by the read of temp from thermal_zone0 blocking, and never completing.
Is there some sort of memory leak or other resource leak in this driver that causes a failure after many repeated reads?
A quick look at the blocking processes currently running on my system, in case the process states are of any help:
pi@raspberrypi ~ $ ps aux|grep cat
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
pi       30071  0.0  0.0   3204   488 pts/1    DN   Jan04   0:00 cat /sys/class/thermal/thermal_zone0/temp
pi       30740  0.0  0.0   3204   488 pts/1    DN   03:16   0:00 cat /sys/class/thermal/thermal_zone0/temp
pi       30755  0.0  0.0   3204   488 pts/1    D+   03:17   0:00 cat /sys/class/thermal/thermal_zone0/temp
Running "cat /sys/class/thermal/thermal_zone0/temp" at the command line will block in such a way that even ctrl-c won't get back to the prompt. Not even kill -9 will kill these "cat" processes...
This is my current Raspbian kernel:
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l GNU/Linux
I'll put off rebooting this system for another day or so in case anyone has any ideas.
by M33P » Sun Jan 06, 2013 4:09 pm
What version of kernel are you running (uname -a)?
What is in the kernel message log (dmesg)?
by milhouse » Sun Jan 06, 2013 4:16 pm
M33P wrote:What version of kernel are you running (uname -a)?
It was in the first post. :)
M33P wrote:What is in the kernel message log (dmesg)?
There is nothing relevant in any of the logs, it just fails silently. I've rebooted now though - have to wait for it to happen again in a few days, though it's not always guaranteed.
by M33P » Sun Jan 06, 2013 4:41 pm
milhouse wrote:It was in the first post. :)
Ha ha failure to read on my part.
Can you remove the delay between temp reads and see if you can hang the command quicker?
e.g. do something like
while true; do cat /sys/class/thermal/thermal_zone0/temp; done
within the shell?
Several Videocore firmware and kernel updates have occurred since that kernel version was released. Maybe updating will help?
by milhouse » Sun Jan 06, 2013 4:57 pm
M33P wrote:Several Videocore firmware and kernel updates have occurred since that kernel version was released. Maybe updating will help?
I tried an rpi-update earlier in the week, which left me with a non-booting system... bit wary of trying again...
Am running the temp loop now, will let you know how it gets on! I modified it as follows so if it hangs I'll know when (and a rough indication of how many times it took)...
X=0; while true; do echo "$(date): $(cat /sys/class/thermal/thermal_zone0/temp) ($(echo $X))"; X=$(($X+1)); done
by milhouse » Mon Jan 07, 2013 1:08 am
The loop process has been running almost 8 hours (1.25m iterations) and no hang so far, however as an experiment I kicked off a second loop in another window and noticed that the temperature returned is very often invalid (a large negative number). This negative value would appear occasionally when running only a single loop, but it is now quite common with two loops (eg. easily every 50-100 reads), would this suggest the thermal driver isn't comfortable with concurrent access?
With two loops, it's now common to see this:
Mon Jan  7 00:57:42 GMT 2013: 57300 (465)
Mon Jan  7 00:57:42 GMT 2013: -854745208 (466)
Mon Jan  7 00:57:42 GMT 2013: 57300 (467)
The negative value can appear in either window, at different times. With only a single loop running, these negative values are extremely rare, though the fact they do appear from time to time, could this be due to a system process also checking the temp?
I've stopped the second loop now, and have allowed the first loop to continue in isolation.
by milhouse » Mon Jan 07, 2013 6:20 pm
OK, success :)
The infinite loop hung overnight, and it failed as follows:
Mon Jan  7 01:48:46 GMT 2013: 57300 (1386574)
Mon Jan  7 01:48:46 GMT 2013: 57838 (1386575)
Mon Jan  7 01:48:46 GMT 2013: 57838 (1386576)
The bottom line is the the last call that succeeded. The hang occurred after 1,386,576 iterations (give or take a couple of thousand when I concurrently ran a second loop which revealed a possibly (un)related concurrency issue). This main loop was started at about 17:06:17 on Jan 6 (just after I booted the Pi), so it took about 8 hours 42 minutes to hang.
Previously I said there was nothing interesting in the logs, but I now take that back. At the time of the hang I have the following in syslog (and also kern.log) - I hope its useful:
Jan  7 01:48:46 raspberrypi kernel: [31346.634917] bcm2708_vcio: mbox chan 8 overflow - drop 5d892008
Jan  7 01:52:18 raspberrypi kernel: [31558.618283] INFO: task kworker/0:2:1656 blocked for more than 120 seconds.
Jan  7 01:52:18 raspberrypi kernel: [31558.618299] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 01:52:18 raspberrypi kernel: [31558.618310] kworker/0:2     D c037a204     0  1656      2 0x00000000
Jan  7 01:52:18 raspberrypi kernel: [31558.618354] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154)
Jan  7 01:52:18 raspberrypi kernel: [31558.618389] [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154) from [<c001a218>] (bcm_mailbox_write+0x34/0xb8)
Jan  7 01:52:18 raspberrypi kernel: [31558.618414] [<c001a218>] (bcm_mailbox_write+0x34/0xb8) from [<c001a390>] (bcm_mailbox_property+0x5c/0xe4)
Jan  7 01:52:18 raspberrypi kernel: [31558.618443] [<c001a390>] (bcm_mailbox_property+0x5c/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 01:52:18 raspberrypi kernel: [31558.618466] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c029704c>] (thermal_zone_device_update+0x2c/0x240)
Jan  7 01:52:18 raspberrypi kernel: [31558.618497] [<c029704c>] (thermal_zone_device_update+0x2c/0x240) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan  7 01:52:18 raspberrypi kernel: [31558.618521] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan  7 01:52:18 raspberrypi kernel: [31558.618547] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan  7 01:52:18 raspberrypi kernel: [31558.618573] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan  7 01:52:18 raspberrypi kernel: [31558.618588] INFO: task cat:18732 blocked for more than 120 seconds.
Jan  7 01:52:18 raspberrypi kernel: [31558.618596] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 01:52:18 raspberrypi kernel: [31558.618606] cat             D c037a204     0 18732   2185 0x00000000
Jan  7 01:52:18 raspberrypi kernel: [31558.618631] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037aea8>] (schedule_timeout+0x198/0x230)
Jan  7 01:52:18 raspberrypi kernel: [31558.618651] [<c037aea8>] (schedule_timeout+0x198/0x230) from [<c037bb9c>] (__down+0x88/0xc0)
Jan  7 01:52:18 raspberrypi kernel: [31558.618672] [<c037bb9c>] (__down+0x88/0xc0) from [<c004809c>] (down+0x60/0x64)
Jan  7 01:52:18 raspberrypi kernel: [31558.618693] [<c004809c>] (down+0x60/0x64) from [<c001a2fc>] (bcm_mailbox_read+0x60/0x98)
Jan  7 01:52:18 raspberrypi kernel: [31558.618716] [<c001a2fc>] (bcm_mailbox_read+0x60/0x98) from [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4)
Jan  7 01:52:18 raspberrypi kernel: [31558.618739] [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 01:52:18 raspberrypi kernel: [31558.618760] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c0296934>] (temp_show+0x28/0x54)
Jan  7 01:52:18 raspberrypi kernel: [31558.618789] [<c0296934>] (temp_show+0x28/0x54) from [<c02232f8>] (dev_attr_show+0x1c/0x48)
Jan  7 01:52:18 raspberrypi kernel: [31558.618818] [<c02232f8>] (dev_attr_show+0x1c/0x48) from [<c0114ff8>] (sysfs_read_file+0x90/0x134)
Jan  7 01:52:18 raspberrypi kernel: [31558.618843] [<c0114ff8>] (sysfs_read_file+0x90/0x134) from [<c00b88c4>] (vfs_read+0x98/0x16c)
Jan  7 01:52:18 raspberrypi kernel: [31558.618862] [<c00b88c4>] (vfs_read+0x98/0x16c) from [<c00b89d0>] (sys_read+0x38/0x70)
Jan  7 01:52:18 raspberrypi kernel: [31558.618883] [<c00b89d0>] (sys_read+0x38/0x70) from [<c000d980>] (ret_fast_syscall+0x0/0x30)
Jan  7 01:54:18 raspberrypi kernel: [31678.608927] INFO: task kworker/0:2:1656 blocked for more than 120 seconds.
Jan  7 01:54:18 raspberrypi kernel: [31678.608942] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 01:54:18 raspberrypi kernel: [31678.608954] kworker/0:2     D c037a204     0  1656      2 0x00000000
Jan  7 01:54:18 raspberrypi kernel: [31678.608997] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154)
Jan  7 01:54:18 raspberrypi kernel: [31678.609033] [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154) from [<c001a218>] (bcm_mailbox_write+0x34/0xb8)
Jan  7 01:54:18 raspberrypi kernel: [31678.609058] [<c001a218>] (bcm_mailbox_write+0x34/0xb8) from [<c001a390>] (bcm_mailbox_property+0x5c/0xe4)
Jan  7 01:54:18 raspberrypi kernel: [31678.609087] [<c001a390>] (bcm_mailbox_property+0x5c/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 01:54:18 raspberrypi kernel: [31678.609109] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c029704c>] (thermal_zone_device_update+0x2c/0x240)
Jan  7 01:54:18 raspberrypi kernel: [31678.609141] [<c029704c>] (thermal_zone_device_update+0x2c/0x240) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan  7 01:54:18 raspberrypi kernel: [31678.609165] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan  7 01:54:18 raspberrypi kernel: [31678.609190] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan  7 01:54:18 raspberrypi kernel: [31678.609216] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan  7 01:54:18 raspberrypi kernel: [31678.609231] INFO: task cat:18732 blocked for more than 120 seconds.
Jan  7 01:54:18 raspberrypi kernel: [31678.609239] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 01:54:18 raspberrypi kernel: [31678.609249] cat             D c037a204     0 18732   2185 0x00000000
Jan  7 01:54:18 raspberrypi kernel: [31678.609274] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037aea8>] (schedule_timeout+0x198/0x230)
Jan  7 01:54:18 raspberrypi kernel: [31678.609294] [<c037aea8>] (schedule_timeout+0x198/0x230) from [<c037bb9c>] (__down+0x88/0xc0)
Jan  7 01:54:18 raspberrypi kernel: [31678.609314] [<c037bb9c>] (__down+0x88/0xc0) from [<c004809c>] (down+0x60/0x64)
Jan  7 01:54:18 raspberrypi kernel: [31678.609337] [<c004809c>] (down+0x60/0x64) from [<c001a2fc>] (bcm_mailbox_read+0x60/0x98)
Jan  7 01:54:18 raspberrypi kernel: [31678.609360] [<c001a2fc>] (bcm_mailbox_read+0x60/0x98) from [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4)
Jan  7 01:54:18 raspberrypi kernel: [31678.609383] [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 01:54:18 raspberrypi kernel: [31678.609404] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c0296934>] (temp_show+0x28/0x54)
Jan  7 01:54:18 raspberrypi kernel: [31678.609433] [<c0296934>] (temp_show+0x28/0x54) from [<c02232f8>] (dev_attr_show+0x1c/0x48)
Jan  7 01:54:18 raspberrypi kernel: [31678.609463] [<c02232f8>] (dev_attr_show+0x1c/0x48) from [<c0114ff8>] (sysfs_read_file+0x90/0x134)
Jan  7 01:54:18 raspberrypi kernel: [31678.609487] [<c0114ff8>] (sysfs_read_file+0x90/0x134) from [<c00b88c4>] (vfs_read+0x98/0x16c)
Jan  7 01:54:18 raspberrypi kernel: [31678.609508] [<c00b88c4>] (vfs_read+0x98/0x16c) from [<c00b89d0>] (sys_read+0x38/0x70)
Jan  7 01:54:18 raspberrypi kernel: [31678.609528] [<c00b89d0>] (sys_read+0x38/0x70) from [<c000d980>] (ret_fast_syscall+0x0/0x30)
Jan  7 01:56:18 raspberrypi kernel: [31798.599576] INFO: task kworker/0:2:1656 blocked for more than 120 seconds.
Jan  7 01:56:18 raspberrypi kernel: [31798.599591] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 01:56:18 raspberrypi kernel: [31798.599602] kworker/0:2     D c037a204     0  1656      2 0x00000000
Jan  7 01:56:18 raspberrypi kernel: [31798.599646] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154)
Jan  7 01:56:18 raspberrypi kernel: [31798.599681] [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154) from [<c001a218>] (bcm_mailbox_write+0x34/0xb8)
Jan  7 01:56:18 raspberrypi kernel: [31798.599707] [<c001a218>] (bcm_mailbox_write+0x34/0xb8) from [<c001a390>] (bcm_mailbox_property+0x5c/0xe4)
Jan  7 01:56:18 raspberrypi kernel: [31798.599735] [<c001a390>] (bcm_mailbox_property+0x5c/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 01:56:18 raspberrypi kernel: [31798.599758] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c029704c>] (thermal_zone_device_update+0x2c/0x240)
Jan  7 01:56:18 raspberrypi kernel: [31798.599790] [<c029704c>] (thermal_zone_device_update+0x2c/0x240) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan  7 01:56:18 raspberrypi kernel: [31798.599815] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan  7 01:56:18 raspberrypi kernel: [31798.599839] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan  7 01:56:18 raspberrypi kernel: [31798.599867] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan  7 01:56:18 raspberrypi kernel: [31798.599881] INFO: task cat:18732 blocked for more than 120 seconds.
Jan  7 01:56:18 raspberrypi kernel: [31798.599889] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 01:56:18 raspberrypi kernel: [31798.599899] cat             D c037a204     0 18732   2185 0x00000000
Jan  7 01:56:18 raspberrypi kernel: [31798.599924] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037aea8>] (schedule_timeout+0x198/0x230)
Jan  7 01:56:18 raspberrypi kernel: [31798.599944] [<c037aea8>] (schedule_timeout+0x198/0x230) from [<c037bb9c>] (__down+0x88/0xc0)
Jan  7 01:56:18 raspberrypi kernel: [31798.599964] [<c037bb9c>] (__down+0x88/0xc0) from [<c004809c>] (down+0x60/0x64)
Jan  7 01:56:18 raspberrypi kernel: [31798.599987] [<c004809c>] (down+0x60/0x64) from [<c001a2fc>] (bcm_mailbox_read+0x60/0x98)
Jan  7 01:56:18 raspberrypi kernel: [31798.600010] [<c001a2fc>] (bcm_mailbox_read+0x60/0x98) from [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4)
Jan  7 01:56:18 raspberrypi kernel: [31798.600034] [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 01:56:18 raspberrypi kernel: [31798.600055] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c0296934>] (temp_show+0x28/0x54)
Jan  7 01:56:18 raspberrypi kernel: [31798.600083] [<c0296934>] (temp_show+0x28/0x54) from [<c02232f8>] (dev_attr_show+0x1c/0x48)
Jan  7 01:56:18 raspberrypi kernel: [31798.600112] [<c02232f8>] (dev_attr_show+0x1c/0x48) from [<c0114ff8>] (sysfs_read_file+0x90/0x134)
Jan  7 01:56:18 raspberrypi kernel: [31798.600137] [<c0114ff8>] (sysfs_read_file+0x90/0x134) from [<c00b88c4>] (vfs_read+0x98/0x16c)
Jan  7 01:56:18 raspberrypi kernel: [31798.600157] [<c00b88c4>] (vfs_read+0x98/0x16c) from [<c00b89d0>] (sys_read+0x38/0x70)
Jan  7 01:56:18 raspberrypi kernel: [31798.600178] [<c00b89d0>] (sys_read+0x38/0x70) from [<c000d980>] (ret_fast_syscall+0x0/0x30)
Jan  7 01:58:18 raspberrypi kernel: [31918.590229] INFO: task kworker/0:2:1656 blocked for more than 120 seconds.
Jan  7 01:58:18 raspberrypi kernel: [31918.590244] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 01:58:18 raspberrypi kernel: [31918.590255] kworker/0:2     D c037a204     0  1656      2 0x00000000
Jan  7 01:58:18 raspberrypi kernel: [31918.590299] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154)
Jan  7 01:58:18 raspberrypi kernel: [31918.590334] [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154) from [<c001a218>] (bcm_mailbox_write+0x34/0xb8)
Jan  7 01:58:18 raspberrypi kernel: [31918.590360] [<c001a218>] (bcm_mailbox_write+0x34/0xb8) from [<c001a390>] (bcm_mailbox_property+0x5c/0xe4)
Jan  7 01:58:18 raspberrypi kernel: [31918.590388] [<c001a390>] (bcm_mailbox_property+0x5c/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 01:58:18 raspberrypi kernel: [31918.590411] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c029704c>] (thermal_zone_device_update+0x2c/0x240)
Jan  7 01:58:18 raspberrypi kernel: [31918.590443] [<c029704c>] (thermal_zone_device_update+0x2c/0x240) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan  7 01:58:18 raspberrypi kernel: [31918.590468] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan  7 01:58:18 raspberrypi kernel: [31918.590493] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan  7 01:58:18 raspberrypi kernel: [31918.590519] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan  7 01:58:18 raspberrypi kernel: [31918.590533] INFO: task cat:18732 blocked for more than 120 seconds.
Jan  7 01:58:18 raspberrypi kernel: [31918.590542] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 01:58:18 raspberrypi kernel: [31918.590551] cat             D c037a204     0 18732   2185 0x00000000
Jan  7 01:58:18 raspberrypi kernel: [31918.590576] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037aea8>] (schedule_timeout+0x198/0x230)
Jan  7 01:58:18 raspberrypi kernel: [31918.590596] [<c037aea8>] (schedule_timeout+0x198/0x230) from [<c037bb9c>] (__down+0x88/0xc0)
Jan  7 01:58:18 raspberrypi kernel: [31918.590617] [<c037bb9c>] (__down+0x88/0xc0) from [<c004809c>] (down+0x60/0x64)
Jan  7 01:58:18 raspberrypi kernel: [31918.590639] [<c004809c>] (down+0x60/0x64) from [<c001a2fc>] (bcm_mailbox_read+0x60/0x98)
Jan  7 01:58:18 raspberrypi kernel: [31918.590662] [<c001a2fc>] (bcm_mailbox_read+0x60/0x98) from [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4)
Jan  7 01:58:18 raspberrypi kernel: [31918.590686] [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 01:58:18 raspberrypi kernel: [31918.590706] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c0296934>] (temp_show+0x28/0x54)
Jan  7 01:58:18 raspberrypi kernel: [31918.590735] [<c0296934>] (temp_show+0x28/0x54) from [<c02232f8>] (dev_attr_show+0x1c/0x48)
Jan  7 01:58:18 raspberrypi kernel: [31918.590764] [<c02232f8>] (dev_attr_show+0x1c/0x48) from [<c0114ff8>] (sysfs_read_file+0x90/0x134)
Jan  7 01:58:18 raspberrypi kernel: [31918.590789] [<c0114ff8>] (sysfs_read_file+0x90/0x134) from [<c00b88c4>] (vfs_read+0x98/0x16c)
Jan  7 01:58:18 raspberrypi kernel: [31918.590809] [<c00b88c4>] (vfs_read+0x98/0x16c) from [<c00b89d0>] (sys_read+0x38/0x70)
Jan  7 01:58:18 raspberrypi kernel: [31918.590829] [<c00b89d0>] (sys_read+0x38/0x70) from [<c000d980>] (ret_fast_syscall+0x0/0x30)
Jan  7 02:00:18 raspberrypi kernel: [32038.580902] INFO: task kworker/0:2:1656 blocked for more than 120 seconds.
Jan  7 02:00:18 raspberrypi kernel: [32038.580919] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 02:00:18 raspberrypi kernel: [32038.580930] kworker/0:2     D c037a204     0  1656      2 0x00000000
Jan  7 02:00:18 raspberrypi kernel: [32038.580974] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154)
Jan  7 02:00:18 raspberrypi kernel: [32038.581010] [<c037b720>] (__mutex_lock_slowpath+0xb8/0x154) from [<c001a218>] (bcm_mailbox_write+0x34/0xb8)
Jan  7 02:00:18 raspberrypi kernel: [32038.581036] [<c001a218>] (bcm_mailbox_write+0x34/0xb8) from [<c001a390>] (bcm_mailbox_property+0x5c/0xe4)
Jan  7 02:00:18 raspberrypi kernel: [32038.581065] [<c001a390>] (bcm_mailbox_property+0x5c/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 02:00:18 raspberrypi kernel: [32038.581088] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c029704c>] (thermal_zone_device_update+0x2c/0x240)
Jan  7 02:00:18 raspberrypi kernel: [32038.581121] [<c029704c>] (thermal_zone_device_update+0x2c/0x240) from [<c003da30>] (process_one_work+0x134/0x38c)
Jan  7 02:00:18 raspberrypi kernel: [32038.581145] [<c003da30>] (process_one_work+0x134/0x38c) from [<c003e4a4>] (worker_thread+0x1a0/0x354)
Jan  7 02:00:18 raspberrypi kernel: [32038.581170] [<c003e4a4>] (worker_thread+0x1a0/0x354) from [<c0042e3c>] (kthread+0x84/0x8c)
Jan  7 02:00:18 raspberrypi kernel: [32038.581197] [<c0042e3c>] (kthread+0x84/0x8c) from [<c000e930>] (kernel_thread_exit+0x0/0x8)
Jan  7 02:00:18 raspberrypi kernel: [32038.581212] INFO: task cat:18732 blocked for more than 120 seconds.
Jan  7 02:00:18 raspberrypi kernel: [32038.581220] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan  7 02:00:18 raspberrypi kernel: [32038.581229] cat             D c037a204     0 18732   2185 0x00000000
Jan  7 02:00:18 raspberrypi kernel: [32038.581254] [<c037a204>] (__schedule+0x2bc/0x568) from [<c037aea8>] (schedule_timeout+0x198/0x230)
Jan  7 02:00:18 raspberrypi kernel: [32038.581274] [<c037aea8>] (schedule_timeout+0x198/0x230) from [<c037bb9c>] (__down+0x88/0xc0)
Jan  7 02:00:18 raspberrypi kernel: [32038.581296] [<c037bb9c>] (__down+0x88/0xc0) from [<c004809c>] (down+0x60/0x64)
Jan  7 02:00:18 raspberrypi kernel: [32038.581319] [<c004809c>] (down+0x60/0x64) from [<c001a2fc>] (bcm_mailbox_read+0x60/0x98)
Jan  7 02:00:18 raspberrypi kernel: [32038.581341] [<c001a2fc>] (bcm_mailbox_read+0x60/0x98) from [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4)
Jan  7 02:00:18 raspberrypi kernel: [32038.581364] [<c001a3d4>] (bcm_mailbox_property+0xa0/0xe4) from [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64)
Jan  7 02:00:18 raspberrypi kernel: [32038.581385] [<c0297e2c>] (bcm2835_get_temp+0x3c/0x64) from [<c0296934>] (temp_show+0x28/0x54)
Jan  7 02:00:18 raspberrypi kernel: [32038.581414] [<c0296934>] (temp_show+0x28/0x54) from [<c02232f8>] (dev_attr_show+0x1c/0x48)
Jan  7 02:00:18 raspberrypi kernel: [32038.581444] [<c02232f8>] (dev_attr_show+0x1c/0x48) from [<c0114ff8>] (sysfs_read_file+0x90/0x134)
Jan  7 02:00:18 raspberrypi kernel: [32038.581468] [<c0114ff8>] (sysfs_read_file+0x90/0x134) from [<c00b88c4>] (vfs_read+0x98/0x16c)
Jan  7 02:00:18 raspberrypi kernel: [32038.581488] [<c00b88c4>] (vfs_read+0x98/0x16c) from [<c00b89d0>] (sys_read+0x38/0x70)
Jan  7 02:00:18 raspberrypi kernel: [32038.581508] [<c00b89d0>] (sys_read+0x38/0x70) from [<c000d980>] (ret_fast_syscall+0x0/0x30)
This is my version of the firmware:
pi@raspberrypi /var/log $ vcgencmd version
Oct 29 2012 23:13:42
Copyright (c) 2012 Broadcom
version 346980 (release)
pi@raspberrypi /var/log $ uname -a
Any attempt to access /sys/class/thermal/thermal_zone0/temp now results in another hung process (but nothing extra written to syslog/kern.log).
by M33P » Mon Jan 07, 2013 7:20 pm
Aha!
That kernel log is a clue.
2 things are accessing the device (i.e. pushing mail into boxes) at the same time. We have
called by a sleeping kernel thread
at nearly the same time as
called by cat.
Note the time difference between the respective accesses - very low! 300us between the two. This is however after a 120 second timeout, but this smells of concurrency issues all over it.
The problem now is that we are in GPU land. The videocore interrupted the ARM to tell it there was a message waiting, but there was no message (==0). Cryptically in vcio.c the associated comment to go with the line in the kernel log is "overflow" - of what?
The associated thermal_zone_device_update is merely checking the temperature at periodic intervals to see if it exceeds a trip threshold - and then halts the processor if it thinks it's on fire.
by milhouse » Mon Jan 07, 2013 7:29 pm
Yes, that and the invalid values when running concurrent tests would suggest a concurrency issue. I've opened issue #132.
Many thanks for your suggestion to run the little script. I'll also update my firmware to the latest (fingers crossed this time), and assuming I can boot will test again.
by milhouse » Mon Jan 07, 2013 8:04 pm
I've successfully updated to:
pi@raspberrypi ~ $ vcgencmd version
Jan  6 2013 20:27:42
version 360762 (release)
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.6.11+ #348 PREEMPT Tue Jan 1 16:33:22 GMT 2013 armv6l GNU/Linux
And have kicked off the test script...
/waits patiently. :)
by M33P » Mon Jan 07, 2013 8:17 pm
milhouse wrote:I've successfully updated to:
Jan  6 2013 20:27:42
Here's how to speed things up
X=0; while true; do echo "$(date): $(cat /sys/class/thermal/thermal_zone0/temp) ($(echo $X))"; X=$(($X+1)); done &
Mine died in 10 seconds flat.
Dec 28 2012 11:22:54
version 359904 (release)
Although my firmware version is a little out of date...
by milhouse » Mon Jan 07, 2013 8:35 pm
M33P wrote:Mine died in 10 seconds flat.
Heh, yeah - mine too. I've updated the issue with this fast way to reproduce and the latest stacktrace.
by stupid_boy » Mon Jan 07, 2013 10:04 pm
this seems very similar to my issue in another thread
viewtopic.php?f=31&t=27908
.... may be location of my thread is wrong, who knows
by milhouse » Mon Jan 07, 2013 10:10 pm
stupid_boy wrote:this seems very similar to my issue in another thread
Looks a little similar. Dom has committed this fix so you might be able to test it yourself soon and see if it helps your hang.
by M33P » Tue Jan 08, 2013 2:48 am
Well the fix has been posted here and has worked its way through to a built image
https://github.com/raspberrypi/linux/co ... f825c53d30
When I run the torture test now, it -
1) No longer locks up (at least not for 5 minutes)
2) Proceeds a bit slower than previously (higher CPU usage)
3) still occasionally returns either a massive negative number or 85000 (85c)
Are the bogus numbers still due to concurrency? Or some bug in the GPU code that's tickled by rapid access
by milhouse » Tue Jan 08, 2013 3:19 am
I've also been running the torture test on the latest kernel with mutex fix for the last 4.5 hours and so far so good - no hangs and no kernel stacktraces. I'll leave it going overnight just to be sure.
M33P wrote:Are the bogus numbers still due to concurrency? Or some bug in the GPU code that's tickled by rapid access
I brought the bogus values to the attention of Dom, and in issue #132 he commented:
The bogus values are a different issue to the hang.
The currently disabled message "Failed to get temperature" does get output when we get a spurious value,
so the temperature driver spots the problem.
I could add a retry, which would avoid the problem, but I'd prefer to understand it...
so looks like it's a separate issue (now open as issue #133), the cause of which isn't entirely clear.
At least the main and more serious culprit has been fixed - thanks for your input on this thread!
by stupid_boy » Tue Jan 08, 2013 1:31 pm
at my side things are even worse now:
