Hi, I've just placed an order for a Pi, so I'm not expecting it to arrive for a few weeks but I've already worked out the first thing I'm going to do which is to install a small chipset heatsink or MOSFET coolers onto the CPU and install a 5v fan into the plastic case.
But I am wanting to know what size the chip is, so that I can purchase the correct size heatsink. Currently looking at a 27mmx27mmx8mm heatsink with thermal tape, would this fit?
Dimensions of the chip?
Typically what people sale are in this range.
size 2pcs 14 * 12 * 5.5 mm Pure copper
size 1pcs 11*11*5MM aluminum
Just so you know what your doing is purely aesthetic. And your better off spending the money on anything else IMHO. The Pi doesn't suffer from heat issues never seen one reported. The Media Center builds do tend to run a bit hotter I think mostly due to extreme overclocking but they still operate well within the range the chips need. It's yours to do with as you please I just don't want anyone to think this is a must have or has to be done. In either case it's a fun project.
malakai wrote:Typically what people sale are in this range.
Thanks for the specs. Could possibly cut the heatsink with a grinder/dremel. And I know it probably won't do anything, I just think it'd look cool and be fun to do.
Some people post pics with large heatsinks try that first so long as it fits in the case no harm no foul.
Out of interest, is there any way to get the current temperature of the CPU?
It would be fun to see who has the coolest runnig Pi
Loving my peice of the Pi
Lonewolff wrote:Out of interest, is there any way to get the current temperature of the CPU?
Or the hottest...
- Code: Select all
pi@raspberrypi ~ $ vcgencmd measure_temp
temp=46.5'C
pi@raspberrypi ~ $
FWIW, I think that's normal. The highest I've seen it go to is 47.6, while running a video with omxplayer. I suppose the next thing to try is 'overclocking'.
Cool, thanks for the snippet.
Joe Schmoe wrote:I suppose the next thing to try is 'overclocking'.
That's the plan.
It's about this big
If you can find a heatsink that small - go for it.
- Moderator
jamesh wrote:It's about this big
I have.
The MOSFET heatsinks are the Enzotech Copper MOS-C1. They come with thermal tape pre-applied, and measure at 6.5(L) mm x6.5mm(W) x12mm(H). So 4x of them on each of the 3 main chips.
Toz wrote:jamesh wrote:It's about this big
I have.
3 main chips?, My working RPi is missing a chip!
He probably has the multiprocessor version.
(starts false rumour, runs and hides)
- Moderator
No, there are three.... the main chip, the one by the USB sockets, and the voltage reg-looking-like-chip next to the electrolytic capacitor. I've seen a pic with heatsinks on all three *somewhere* on the internet
EDIT! Heatsink kit here! :
https://www.modmypi.com/shop/raspberry-pi-heat-sink-kit
Photo (but not of the ones sold above...):
http://i1072.photobucket.com/albums/w36 ... CN0915.jpg
More EDIT! Or water cool it here!SoggyPi:
http://redharbinger.com/forums/threads/soggy-pi.1102/
Geez, if you want to play like that, then there are actually five - RG1, RG2, RG3, IC2, IC3.
Good luck finding a heatsink that measures 2 x 4 millimetres though
