I have just tried to get rid of a file but it say i need to be a superuser how would i be able to make my self one and how would i be able to make new users?
I am currently logging in as pi.
How do I make my self admin and use admin commands
You need sudo before a command to make it run with admin (root) rights, alternatively you could just use sudo su instead to login as root without a password.
Richard S.
Richard S.
it wont let me login as root!
what command in the LXTerminal do I need to do to make pi a admin?
To run commands as root prefix them with "sudo", as in "sudo rm /that/file" or similar. You'll be prompted to enter your password. This only works if you have permissions granted for sudo via the file /etc/sudoers (but user pi has that permission). If you want to do lots as user root, you can do "sudo bash" to give you a shell prompt with root privileges.
To create new users from the command line at least, use the "useradd" command. Type "man useradd" to figure out how..
so how would i delete the file?
how do i delete it?
User pi is already an admin, unless you have changed something. To delete a file:computerguy123 wrote:what command in the LXTerminal do I need to do to make pi a admin?
- Code: Select all
rm FILE
- Code: Select all
sudo rm FILE
