superuser
hello im new and i also have a problem i dont know waht the standard password is for su
please help
There isn't one. Set it with 'sudo passwd root'
- Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Its "superuser" - the thread title is confusing
Root has no password on Raspbian , therefore you have to use
sudo su.
It is recommeneded to drop su and use sudo instead.
ghans
sudo su.
ghans
so waht do i have to type in the terminal to log in to su
If you are on the newest Raspbian and booting for the first time :
Username : pi
Password : raspberry
You won't see any stars or anything , just type blindly.
ghans
Username : pi
ghans
- Code: Select all
sudo -i
will get you into a superuser shell.
