GPIO interrupts
by _Stephan_ » Fri Dec 28, 2012 6:51 pm
Hello together,
I am using rPi with the current wheezy image.
To access the GPIOs (c program) I am using the bcm2835 lib from Mike McCauley.
Today I tried the event example and found out, that the if condition never was true.
    // Set RPI pin P1-15 to be an input
    bcm2835_gpio_fsel(PIN, BCM2835_GPIO_FSEL_INPT);
    //  with a pullup
    bcm2835_gpio_set_pud(PIN, BCM2835_GPIO_PUD_UP);
    // And a low detect enable
    bcm2835_gpio_len(PIN);
    while (1)
      if (bcm2835_gpio_eds(PIN))
         // Now clear the eds flag by setting it to 1
         bcm2835_gpio_set_eds(PIN);
         printf("low event detect for pin 15\n");
      // wait a bit
      delay(500);
If the GPIO was low, the program freezes.
In the forum I found a similar problem with an explanation, that this could be a CPU interrupt problem.
I have had a look at the datasheet and disbled the GPIO interrupts and now it works.
Does anybody know if the rPi needs the interrupt (gpio_int[0] #52) for any other things?
The datasheet is not really precise in the explanation of the GPIO interrupts.
Can anybody explain the interrupt function?
Thank you in advance.
Stephan
by pjc123 » Sat Dec 29, 2012 11:51 am
From Mike Mike McCauley's main page:
"CAUTION: it has been observed that when detect enables such as bcm2835_gpio_len() are used and the pin is pulled LOW it can cause temporary hangs on 2012-07-15-wheezy-raspbian and Occidentalisv01. Reason for this is not yet determined, but suspect that an interrupt handler is hitting a hard loop on those OSs. If you must use bcm2835_gpio_len() and friends, make sure you disable the pins with bcm2835_gpio_cler_len() and friends after use."
I don't need edge detection, so I use the following command to detect a low or high:
bcm2835_gpio_lev
