- Code: Select all
Linux pi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l
The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
Last login: Thu Dec 20 20:08:18 2012 from 192.168.1.14
Removing log in warranty-warning?
When logging in I get a warning on Raspbian wheezy.
It comes from /etc/motd (message of the day).
It is the Message Of The Day...
/etc/motd contains:
You can replace the with your own message or delete for no additional message.
Note: You need to have root privileges to modify /etc/motd
Enjoy!
/etc/motd contains:
- Code: Select all
Enjoy!
Can I comment lines in motd?
Is it text only? I currently have a script in .bashcr that gives me the IP and some more stuff, could I put this in the motd? The .bashcr script takes a few seconds after the motd to load.
EDIT: Should have checked the comment thing by myself, and I couldn't comment it.
