by
doveman » Tue Feb 26, 2013 11:17 am
If the hub just needs to see +5v on the miniUSB port as well as the PSU plug, perhaps I can solder the miniUSB +5v to the +5v coming from my UBEC, rather than the USB plug in the RPi? Then there's no way that it can draw any power through the RPi, not that it should be anyway with the hub powered directly from the UBEC (when this power is connected the lights on the hub get a lot brighter so I can tell it's drawing from the UBEC) but you never know I guess.
I've been having a mare with it recently anyway. Whereas before Christmas the hub was working fine with three devices (remote receiver, USB tuner and USB stick) in the three inside ports on the hub, now I can only get it to work with the remote receiver on port1 and the USB stick on port3 (I'm not using the tuner anymore). Any other combination and it won't boot.
Then even this stopped working and I had to put the remote receiver on the other, outer, side of the hub. If I use a ready-made cable however, it works with both devices on the inside of the hub again, so I may just have to cut a big hole in my case to fit the moulded-plug on this cable.
I also tried my home-made cable in the bottom port on the RPi and that didn't work, so I can only assume the connector doesn't made a good connection in that for some reason. The ready-made cable works OK in it.
