Hi, I'm new here, I installed apache2 on my raspberry pi and i changed the root file /home/pi/Desktop/serv/ instead of /var/www
I can successfull log on the index.html page but the problem is that i cannot see my background picture. The picture is saved in /home/pi/Desktop/serv/picture.png but the background doesn't appear...
I tried this : http://192.168.1.25/picture.png and it show the picture i'm suppose to view as my background page.
I tried to change the root of by background in my index.html file to : http://192.168.1.25/picture.png and it's work....
What is the problem?
Apache2
home/pi/Desktop/serv/[/quote]
did you check if apache has permission on the new directory? At least it should have permission to read.
Try this:
Tobi
Try this:
- Code: Select all
chmod 777 /home/pi/Desktop/serv
Tobi
okay i will try his tonight!
The result when im over the internet is :
Not Found
The requested URL /home/pi/Desktop/serv/Genbt.html was not found on this server.
Apache/2.2.22 (Debian) Server at www.btcad.dyndns.info Port 80
Not Found
btguillaume wrote:okay i will try his tonight!
Not Found
Apache/2.2.22 (Debian) Server at http://www.btcad.dyndns.info Port 80
In your HTML code you've got
- Code: Select all
{background:url("home/pi/Desktop/serv/blackground.png");
Should be:
- Code: Select all
{background:url("blackground.png");
Your webservers location isn't in /home/, it's in /home/pi/Desktop/serv/. The base directory for any file or anything on your webserver starts in /serv/. If you want to load an image over the net that's located in /serv/ you just type www.yoururl.com/image.jpg. Not www.yoururl.com/home/pi/Desktop/serv/image.jpg.
Okay, thats make sense....
background-color: #0e0e0e;
background-repeat:no-repeat;
should be :
I will try it asap!
thanks a lot
should be :
I will try it asap!
thanks a lot
It works!
Perfect! thanks a lot.
My next question:
With apache2 , can i get videostream from an ipcamera like http://192.168.1.151:8081 over the internet? Or I may use DYN like http://mycam.dyndns.com:8081 ?
ports 8081 opened on my router.
My next question:
btguillaume wrote:With apache2 , can i get videostream from an ipcamera like http://192.168.1.151:8081 over the internet? Or I may use DYN like http://mycam.dyndns.com:8081 ?
You can watch what you can see on your webcam in the network with http://192.168.1.151:8081. Then you normally have a login window before you see the picture...
If you want to include your camera to your website you need a dyndns account, like you wrote. And then you should include it with an iframe. For that you need the whole url to the video stream with login. Maybe looks like: http://192.168.1.151:8081/cam.php?user=test&pw=test. That depends on your ipcamera.
If you don't know the url, just use google "embed camera +Camera model".
Tobi
Thanks again!
Is it possible to change de soure code from a page with a external file with variable field?
For exemple :
Mydomain.dyndns.com/Gentbt1.html : (or/Genbt2.html)
Genbt1.html
namevar1
namevar2
Genbt2.html
namevar3
namevar4
I would like to change those ( namevar 1-2-3-4 ) from an external file called name_to_setup.???
Is it possible to do that with javascript or something like that? Those names are not in <body></body>
They are in the source code.
Any suggestions?
Thx a lot guys for your help!
For exemple :
Genbt1.html
namevar1
namevar2
Genbt2.html
namevar3
namevar4
Any suggestions?
