Introducing the Pi Store!
Page 1 of 2 1, 2
Today, with the help of our good friends at Indiecity and Velocix, we've launched a new feature for your Raspberry Pi. Read more about it at this blog post, download it to your Pi, and come back and discuss it here!
This is fantastic to share projects with others, Just what the Pi needed.
Must run an update first though to install the PiStore.
- Code: Select all
sudo apt-get update && sudo apt-get install pistore
This is cool.
Congratulations to everyone involved.
ghans
ghans
Pleased to meet you, Pi Store!
Pi Store sounds like a good idea but are the apps tested and scrutinised before they're released to the general public i.e. bugs, and naughty lines of code??
Richard S.
Richard S.
They are moderated.
- Moderator
I can confirm that any submissions to the store are manually checked before they are approved to be listed for download. The main things that we're checking for are that it runs without error on the Pi and doesn't contain any illegal content, themes or copyright/license infringements.
- Moderator
An excellent development. There does seem to be some conflicting information relating to licensing in places, for example ... http://store.raspberrypi.com/projects/libreoffice
"Developer's Description : You can download, install and distribute LibreOffice freely, with no fear of copyright infringement"
"Licence : Game/App EULA : You may not modify or redistribute this content"
Same Game/App EULA for "open source" http://store.raspberrypi.com/projects/despotify
Very nice.
I do notice that there are 25 applications listed, and 259 developers registered. That's an average of 0.097 applications each. Maybe there are 234 apps in an "advanced stage of development"
Or possibly it would be better not to list developers until they publish.
ruwin - I don't think it distinguishes between Indiecity Developers and those who are Pi Store focussed, hence the apparently large number of devs signed up.
- Moderator
I'm trying to upload WebIOPi...
But when registered as a developer, we are redirected to indiecity without ability to specify a "Raspberry Pi" project...
Also, is there any guideline to upload apps for the Pi ?
WebIOPi - Raspberry Pi REST Framework to control your Pi from the web
http://store.raspberrypi.com/projects/webiopi
http://code.google.com/p/webiopi/
http://trouch.com
Are you on PC when doing this? In order to upload currently you need to be in the Pi Store on the Pi itself, and then use the Upload section.
Very soon you will be able to upload from PC as well, and a detailed instructions page will shortly be provided.
ChrisSwan wrote:Are you on PC when doing this? In order to upload currently you need to be in the Pi Store on the Pi itself, and then use the Upload section.
On another computer (not a PC
I'll try to add a remote desktop on my Pi to do it because I don't have any screen to plug in.
Many thanks for your feedback
http://trouch.com
Will there be command line access to the Pi Store?
Will it ever run on archlinuxarm?
If you want someone to help test, I have a rev1.1 board and an SD card that i'm willing to put to work testing apps from the pi store
Its got one broken USB port, but other than that its working, and i'm more than happy to set aside an SD card, and isolate the pi from my network, so i dont have to worry about virus's.
Offers there if you want it
mahjongg wrote:Wishful thinking is a bitch isn't it.
Hi I've done the sudo apt thing above to download pi store now how do I run / open it as nothing happens. I might be having a blonde moment but at moment it does nothing.
Hi smstext,
If you type 'pistore' into a terminal, what happens? Does it output any text or errors?
Thanks very much,
~Richard Williams
Thanks very much,
~Richard Williams
You can register as a developer from a PC. I did. I'm converting some JavaME phone code to JavaFX, and then adding to it. I hope to have it done round about when the oracle VM is in full release. Just wondering what the situation is with LinuxPC/Pi dual release is. Do you just upload one thing and select 2 platforms or is a double upload needed? I could have two startup scripts in the one release. It could even work on windows if someone else wrote the startup script.
It would be nice if the start up scripts were automated to be added to the download after finding the Application class. Also nice to have would be an addition to the download of a helper process which could be configured to send key presses to the Application Scene. This would in effect make a keyboard the standard controller, and make all applications automatically joypad compatible.
Pi=B256R0USB CL4SD8GB Raspbian Stock. 13D It's tidal coupling time. https://dl.dropboxusercontent.com/u/1615413/Own%20Work/Dimensions.pdf ... Looking for an interesting project to hold my attention.
Hi jackokring,
You need to do a separate upload for each platform, but these can all be managed under the one project. If you just select a new platform in the project's 'Platforms/Installers' tab, you're presented with a set of Upload/Build buttons for each platform.
Hope that helps,
~Richard Williams
jackokring wrote:Just wondering what the situation is with LinuxPC/Pi dual release is. Do you just upload one thing and select 2 platforms or is a double upload needed? I could have two startup scripts in the one release. It could even work on windows if someone else wrote the startup script.
Hope that helps,
~Richard Williams
I'm getting error whilst loading shared libraries: 23_server_method: cannot open shared object file: no such file or directory
Thanks for posting the error.
Hrm - I'll admit it's not one I've seen before. Sounds like a missing dependency though. Would you mind removing and reinstalling the Pi Store, if you haven't already?
Also, are you on a fairly new Raspbian image (I'm not aware of any problems with older images, but I'd recommend being as up-to-date as possible)? Have you removed any packages which came on the image?
Sorry for all the questions - I'm just trying to work out what it's most likely to be.
Thanks again for your help,
~Richard Williams
~Richard Williams
I've removed and reinstalled pistore and no difference. Looks like I'm just going to have to wipe the sd card and start afresh and put all the stuff back on it.
that's great. love to see more apps on the store soon.
update, i formatted the card and reinstalled raspbian, all works fine now.
