I have been steadily learning more and more about the Pi and Linux, and this is the first time I have had to ask for help. I am not sure if I am headed down the correct path.
What I want ot do is load and play a .PPS file with LibreOffice when the Pi boots. Is there an easy way to do this? Do I need to switch to the LDXE Desktop to make this easier? Or create a script in /etx/init.d?
I am all about learning! But I am honestly stumped and somewhat of a newbie with Raspbian and the Pi.
Please, if someone has an example I could look at to point me in the right direction, I would appreciate it.
I want to autoplay a Powerpoint PPS file on Boot. Help?
AFAIK X has to be started.
You should investigate LibreOffices command-line switches to start
it in presentation mode.
http://www.debian-administration.org/articles/50
Hope above link sheds some light on the autostart issue.
ghans
ghans
Thank you, but I still need help.
Please elaborate.
ghans
ghans
1) The Pi is running Raspbian and X is always started on boot.
2) LibreOffice does not support a "loop" from command line, so even though I created a script and made it executable under /etx/X11/Xsession.d, the presentation will run once, then stop and wait for Esc to be pressed. I tried ImpressRunner, but that didn't work either.
I am looking for a solid solution, because not only am I a beginner and am learning as I go, the people I work with know less about Linux in general than I do. Some options that I considers and rejected because I don't want the even more clueless end user to have a chance to break anything are:
Converting Powerpoint to movie / jpg / whatever - Extra steps on the end user side are off the table as per the IT boss.
RDP in and start the Presentation manually - I like this idea, but xrdp did not mirror what was going on on the actual Pi desktop... IE I started the slideshow on the Windows PC's RDP Window, but the Pi screen remained the standard desktop and didn't show the Powerpoint slideshow.
You need to run LibreOffice and go to Slide Show->Slide Show Settings
Set type to auto. Close LO and it should be saved to your user preferences. You will need to start LO as this user though.
Mr Floppy wrote:You need to run LibreOffice and go to Slide Show->Slide Show Settings
This may save the slideshow rules when playing the PPS from within LO, but starting the PPS from command line on boot using libraoffice -show /[path to PPS] will only play the presentation once, then displays the "Press ESC to Exit" message, when started from a script.
Have you tried launching it in your local xsession start up file?
~/.xsession
It may behave differently with PATHS when launched from the global xsession file. I'm pretty sure it reads the config files from the command line as well, at least in headless mode anyway. You could test it out by running it from a terminal.
~/.xsession
