Hello all
I cannot seem to ssh into my pi. I've tried everything i can think of
It's the latest build (ssh should be enabled)
Router is DHCP
IP is bound to MAC address
Tried different IP
Used both PuTTY and the terminal on my ubuntu machine
It responds to ping
Port 22 is open
Different power supplies
Different patch cables
Sometimes it returns connection refused, sometime connection timed out
I'm hoping someone can suggest something else to try as im at a loss
Cheers
Cannot get ssh to work
Check to see if another machine has the same IP address as the Pi.
Have you made sure that you are communicating with the correct IP address? ssh -v should tell you what IP is being connected to.
Assuming Raspbian? Did you enable the ssh server when raspi-config ran the first time you booted? Does netstat show port 22 listening:
If not, enable it in: sudo raspi-config
- Code: Select all
efflandt@raspberrypi ~ $ netstat -ltn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:6011 0.0.0.0:* LISTEN
Hi
no conflict with ip and ip correct. I will check port out later tonight.
I tried setting it up headless, but when that failed I hooked it up to the tv and did the initial startup config there. unfortunately no LAN near the tv, so I had to set it up offline
apologies, yes it is the raspian wheezy build 28/10/12
hello
netstat reports port 22 is listening.
ssh enabled in config
Still get connection refused
Tom
Tom
What does ssh -v say? Are you sure you are using ssh correctly? For example, using the -l option to ensure that you are logging into the 'pi' account.
I do not think that there is enough information for us to help at this time.
Mursili wrote:Have you made sure that you are communicating with the correct IP address? ssh -v should tell you what IP is being connected to.
It was this. I could've sworn i had the right IP!
ifconfig eth0, then face palm.
pi working fine, thanks for the input and apologies for any wasted time
