NTP with DCHP
Hi, this is my first post on the forum, I have searched the forum for an answer with no luck, I´m trying to get my Pi to update the date and time using NTP and I have tried every solution on the forum and I came to a conclution that the DHCP configuration of my wireless router is screwing up my Pi and not letting it get connected to the NTP servers, I´m a noob when it comes to linux so a step by step answer will be appreciated and thank you in advance.
Judging from the system logs and /etc/services, ntp uses UDP port 123 to poll ntp servers and that should happen soon after you get IP and everything from a dhcp server (your router).
Does following command show an IP address for eth0 (or wlan0 if wireless): ifconfig
Does following show a default gateway (UG) to your router IP: route -n
Does following show at least one nameserver (often router IP): cat /etc/resolv.conf
Does /var/log/syslog show eth0 errors or any USB devices dropping out (a sign of not enough voltage or something on USB using too much power or not supported).
First of all thank you efflandt for a quick reply, I have my Pi connected using wireless module and in the ifconf I only have the SSID and password of my wireless lan, I maneged to fix the IP address of my Pi thru my wireless router, because I´m using it as a headless box
The route -n command it shows the IP address of my router as the gateway wich I guess is the way it should be.
On cat /etc/resolv.conf I have as a servername the IP address of my router
And finally in the /var/log/syslog I have a LOT of entries and I could´nt find any related to my internet connection or NTP
Thank you one more time for your help
my ntp servers and clients run under dhcp with no problem
could you post your /etc/ntp.conf file? and the result of 'grep ntpd /var/log/daemon.log' ?
best regards
Dave
best regards
Dave
Hi morgad, this is my /etc/ntp.conf file:
And this is my /var/log/daemon.log file is too large to post it.
May be if you give me some instruction on what you did to get your Pi working on DHCP I could get mine too and thank you.
- Code: Select all
# /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
# Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
# You do need to talk to an NTP server or two (or three).
server ntp.timeserver.com
# pool.ntp.org maps to about 1000 low-stratum NTP servers. Your server will
# pick a different set every time it starts up. Please consider joining the
# pool: <http://www.pool.ntp.org/join.html>
#server 0.debian.pool.ntp.org iburst
#server 1.debian.pool.ntp.org iburst
#server 2.debian.pool.ntp.org iburst
#server 3.debian.pool.ntp.org iburst
server 0.south-america.pool.ntp.org
server 1.south-america.pool.ntp.org
server 2.south-america.pool.ntp.org
server 3.south-america.pool.ntp.org
server 4.br.pool.ntp.org
# Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
# details. The web page <http://support.ntp.org/bin/view/Support/AccessRestrictions>
# might also be helpful.
# Note that "restrict" applies to both servers and clients, so a configuration
# that might be intended to block requests from certain clients could also end
# up blocking replies from your own upstream servers.
# By default, exchange time with everybody, but don't allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery
restrict -6 default kod notrap nomodify nopeer noquery
# Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict ::1
# Clients from this (example!) subnet have unlimited access, but only if
# cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
# If you want to provide time to your local subnet, change the next line.
# (Again, the address is an example only.)
#broadcast 192.168.123.255
# If you want to listen to time broadcasts on your local subnet, de-comment the
# next lines. Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient
Hi
I did nothing to get ntp working with dhcp, it just works.
(I am running Rasbian here)
I tried your ntp.conf file, and it worked (although there are some minor problems)
(ntp.timeserver.com is not an ntp server, server 4.br.pool.ntp.org does not resolve (only 0-3 prefixes are valid))
if ntpq -pn gives 'ntpq: read: Connection refused' then ntp is not running, try
'tail -f /var/log/daemon.log' in one terminal window and then 'sudo service ntp restart' in the other
and see if you get any error messages in the log, my running systems gives
on your ntp.conf file
hope this helps narrow down the problem
best regards
Dave
- Code: Select all
$ntpq -pn
remote refid st t when poll reach delay offset jitter
176.74.176.167 .INIT. 16 u - 1024 0 0.000 0.000 0.000
-200.69.222.89 170.210.222.2 4 u 113 128 377 238.287 1.285 0.467
*200.186.125.195 .ONBR. 1 u 35 128 377 206.004 0.710 0.425
+200.37.61.61 149.20.64.28 2 u 107 128 377 181.360 -1.930 0.662
+200.192.232.8 200.160.7.186 2 u 103 128 377 245.560 4.458 0.513
- Code: Select all
Dec 14 18:08:53 raspberrypi2 ntpd[4912]: ntpd 4.2.6p5@1.2349-o Fri May 18 20:30:57 UTC 2012 (1)
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: proto: precision = 1.000 usec
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: Listen normally on 1 lo 127.0.0.1 UDP 123
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: Listen normally on 2 eth0 192.168.1.27 UDP 123
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: peers refreshed
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: Listening on routing socket on fd #19 for interface updates
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: restrict: error in address '::' on line 39. Ignoring...
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: restrict: error in address '::1' on line 43. Ignoring...
Dec 14 18:08:53 raspberrypi2 ntpd[4913]: Deferring DNS for 4.br.pool.ntp.org 1
Dec 14 18:08:53 raspberrypi2 ntpd[4933]: signal_no_reset: signal 17 had flags 4000000
Dec 14 18:08:55 raspberrypi2 ntpd_intres[4933]: host name not found: 4.br.pool.ntp.org
Dec 14 18:09:57 raspberrypi2 ntpd_intres[4933]: host name not found: 4.br.pool.ntp.org
Dec 14 18:11:59 raspberrypi2 ntpd_intres[4933]: host name not found: 4.br.pool.ntp.org
Dec 14 18:16:01 raspberrypi2 ntpd_intres[4933]: host name not found: 4.br.pool.ntp.org
Dec 14 18:24:04 raspberrypi2 ntpd_intres[4933]: host name not found: 4.br.pool.ntp.org
Dec 14 18:40:07 raspberrypi2 ntpd_intres[4933]: host name not found: 4.br.pool.ntp.org
best regards
Dave
Anybody established if the OP's internet works yet ?
Would be a reasonable starting place. The internet settings being right aren't the same as the internet actually working.
The standard ntp settings work fine, if there is an internet connection
- Code: Select all
ping 8.8.8.8
ping www.google.com
Hi morgad, I fixed what you found on my /etc/ntp.conf file and then I did a reboot and I still get no awnser from any ntp server, and when I run ntpq -pn I get this:
When I try the "tail -f /var/log/daemon.log" I get:
The last thing that I´m guessing is that my router is blocking the ntp servers.
And yes pluggy that was the fisrt thing that I did, if I could ping any site.
- Code: Select all
200.160.0.8 .INIT. 16 u - 64 0 0.000 0.000 0.000
200.186.125.195 .INIT. 16 u - 64 0 0.000 0.000 0.000
200.192.112.8 .INIT. 16 u - 64 0 0.000 0.000 0.000
200.1.22.6 .INIT. 16 u - 64 0 0.000 0.000 0.000
- Code: Select all
Oct 29 20:50:38 raspberrypi ntpd[2189]: ntpd exiting on signal 15
Oct 29 20:50:40 raspberrypi ntpd[2640]: ntpd 4.2.6p5@1.2349-o Fri May 18 20:30:5 7 UTC 2012 (1)
Oct 29 20:50:40 raspberrypi ntpd[2641]: proto: precision = 1.000 usec
Oct 29 20:50:40 raspberrypi ntpd[2641]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Oct 29 20:50:40 raspberrypi ntpd[2641]: Listen normally on 1 lo 127.0.0.1 UDP 12 3
Oct 29 20:50:40 raspberrypi ntpd[2641]: Listen normally on 2 wlan0 192.168.0.122 UDP 123
Oct 29 20:50:40 raspberrypi ntpd[2641]: peers refreshed
Oct 29 20:50:40 raspberrypi ntpd[2641]: Listening on routing socket on fd #19 fo r interface updates
Oct 29 20:50:40 raspberrypi ntpd[2641]: restrict: error in address '::' on line 41. Ignoring...
Oct 29 20:50:40 raspberrypi ntpd[2641]: restrict: error in address '::1' on line 45. Ignoring...
Oct 29 20:59:13 raspberrypi ntpd[2641]: ntpd exiting on signal 15
Oct 29 20:59:15 raspberrypi ntpd[2723]: ntpd 4.2.6p5@1.2349-o Fri May 18 20:30:57 UTC 2012 (1)
Oct 29 20:59:15 raspberrypi ntpd[2724]: proto: precision = 1.000 usec
Oct 29 20:59:15 raspberrypi ntpd[2724]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Oct 29 20:59:15 raspberrypi ntpd[2724]: Listen normally on 1 lo 127.0.0.1 UDP 123
Oct 29 20:59:15 raspberrypi ntpd[2724]: Listen normally on 2 wlan0 192.168.0.122 UDP 123
Oct 29 20:59:15 raspberrypi ntpd[2724]: peers refreshed
Oct 29 20:59:15 raspberrypi ntpd[2724]: Listening on routing socket on fd #19 for interface updates
Oct 29 20:59:15 raspberrypi ntpd[2724]: restrict: error in address '::' on line 41. Ignoring...
Oct 29 20:59:15 raspberrypi ntpd[2724]: restrict: error in address '::1' on line 45. Ignoring...
Oct 29 20:59:53 raspberrypi wpa_supplicant[1504]: wlan0: WPA: Group rekeying completed with 14:d6:4d:38:3a:54 [GTK=TKIP]
