Here's a list of wireless adapters I've been able to gather that supposedly work well with the Pi on Arch:
Alfa Network AWUS036NH
USB ID: 148f:3070
Chipset: Ralink RT3070
Driver: rt2800usb or rt2870sta
USB hub:
Works out of box:
Asus USB-N10
USB ID: 0b05:1786
Chipset: Realtek RTL8188SU
Driver: r8712u
USB hub: Recommended
Works out of box:
Belkin Components F6D4050 v1
USB ID: 050d:935a
Driver: rt3572sta (recommended) or rt2800usb or rt2870sta
USB hub:
Works out of box:
Belkin Components F7D1101 v1
USB ID: 050d:945a
Driver: r8712u
USB hub:
Works out of box:
BlueProton BT3
USB ID: 0bda:8187
Chipset: Realtek RTL8187L
Driver: rtl8187
Works out of box:
D-Link AirPlus G DWL-G122 (rev. B1)
USB ID: 2001:3c00
Chipset: Ralink RT2571 & RT2526
Driver: rt2500usb
USB hub:
Works out of box: Yes
D-Link AirPlus G DWL-G122 (rev. C1)
USB ID: 07d1:3c03
Chipset: Ralink RT2571W & RT2528
Driver: rt73usb
USB hub:
D-Link DWA-123 vA1
USB ID: 2001:3c17
Chipset: Ralink RT3370 (RT2800?)
Driver: rt2800usb (experimental) or rt3380sta
USB hub: Not required
Edimax EW-7711UAn
USB ID: 7392:7711
Chipset: Ralink RT2870
Works out of box:
IOGear GWU625
USB ID: 0bda:8172
Chipset: Realtek RTL8191SU
Driver: r8712u
Works out of box:
Linksys (Cisco) WUSB100 v2
USB ID: 1737:0078
USB hub:
Rosewill RNX-N180UBE Wireless B/G/N Adapter
USB ID: 0bda:8172
Driver: r8712u
USB hub: Required
Rosewill RNX-G1 Wireless B/G Adapter
USB ID: 0bda:8187
Driver:
USB hub: Required
TP-Link TL-WN821N v3
USB ID: 0cf3:7015
Chipset: Atheros AR7010 & AR9287
Driver: ath9k_htc
USB hub: Required
Which one have you had the most success with? The DWL-123 looks nice since it supposedly doesn't require a powered USB hub, but it's damn hard to find.
In case you're curious, here are my sources:
RPi Verified Peripherals on eLinux
Ralink Chipsets on WikiDev
Realtek Chipsets on WikiDev
Atheros Chipsets on WikiDev
Best Arch WiFi adapter
Page 1 of 2 1, 2
These chipsets work well, both need firmware put into /usr/lib/firmware and can be access points
http://linuxwireless.org/en/users/Drivers/carl9170
http://wireless.kernel.org/en/users/Drivers/p54
pepedog, are you saying that any device with either of those chipsets will work as long as the firmware is installed? Correct me if I'm wrong, but I think the firmware for the devices I listed is already included in the kernel.
Yes.
I don't think firmware is in the kernel (ie built in, I would have noticed that) but maybe there, in place, or no firmware required
davidkennedy85 wrote:D-Link DWA-123 vA1
USB ID: 2001:3c17
USB ID: 0cf3:7015
Driver: ath9k_htc
USB hub: Required
I wish there was a way to edit posts. That D-Link DWA-123 should read rt2800usb (experimental) or rt3370sta. Also, I should mention the TP-Link TL-WN821N v3 may require the additional firmware htc_7010.fw. The eLinux page lists it as "out of box" though, so maybe the firmware is not necessary or is already there.
Im using a 0846:9041 NetGear, Inc. WNA1000M 802.11bgn [Realtek RTL8188CUS] out of the box without a powered hub.
Seems to be a bit flakey, but Im not sure if that's why AdHoc network/setup or the hardware/driver.
Would be great to find a small dongle like this that is known to be reliable on Arch.
Old school Alfa AWUS036H (0bda:8187 Realtek Semiconductor Corp. RTL8187 Wireless Adapter) works fine for me.
I should have updated this thread a while ago, but I can verify that the TP-Link TL-WN821N v3 works beautifully out of the box with no additional firmware required.
So the TP-Link TL-WN821N v3 works fine out of the box, but does it definitely need a USB hub?
I always use a USB Powered Hub, had had dis--connects without.
Presently am using generic Chinese Ebay USB Wireless Adaptors
Realtek RTL8188CUS Chipset Works OK...
Ralink RT5370 Chipset Recognised but will not connect....
both cost under a fiver !
http://archlinuxpi.blogspot.co.uk
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
Thanks for the reply.
I will most likely be using it for the car so I would rather not have the hub. I bought the TL-WN723N to try out, apparently it doesn't need a hub and works fine, aside from the heat.
So I bought the TL-WN723N and tried it OOTB as the Wiki states and also tried with a USB hub and still no go. Looks like a driver issue... "Association request to the driver failed".
anicho wrote:So I bought the TL-WN723N and tried it OOTB as the Wiki states and also tried with a USB hub and still no go. Looks like a driver issue... "Association request to the driver failed".
Works fine on my 512MB rpi with the 3.6-kernel (the -next packages) using netcfg with wpa_supplicant to connect to a WPA2-secured WLAN.
This is what lsusb lists is as:
- Code: Select all
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Raspberry Pi (rev 000f, 512MB RAM) with heatsinks and a modmypi case running Arch Linux ARM (armv6h) hooked up to a 750GB 2.5" USB-harddrive
drirr wrote:anicho wrote:So I bought the TL-WN723N and tried it OOTB as the Wiki states and also tried with a USB hub and still no go. Looks like a driver issue... "Association request to the driver failed".
- Code: Select all
Actually I done a lsusb and mine comes up with the same.
Useful thread, guys. Further to the original question, can anyone recommend a wifi dongle that works well under Arch AND supports master mode, i.e. suitable for creating a software AP?
anicho wrote:drirr wrote:anicho wrote:So I bought the TL-WN723N and tried it OOTB as the Wiki states and also tried with a USB hub and still no go. Looks like a driver issue... "Association request to the driver failed".
- Code: Select all
Are you using netcfg or are you just starting wpa_supplicant and then dhcpd (or ifconfig for a static ip)? Assuming you're trying to connect to a WPA-encrypted WLAN.
I was just using the WiFi tool on the desktop of the latest raspbian
https://wiki.archlinux.org/index.php/Ne ... CP_at_boot
Basically if netcfg starts before network comes up, insert the module as described
ie if module is called r8169
Please do not take this literally, you module is probably not r8169, lsmod will tell you
- Code: Select all
cat r8169 > /etc/modules-load.d/r8169.conf
How do you know which it is in lsmod... Closest I see is 8192cu its all random. I tried lspci -k as suggested on the wiki but it gets errors.
Also should there already be a folder modules-load.d as I didn't have it so I created also.
That is the one, so you want
Then
sync
reboot
- Code: Select all
cat 8192cu > /etc/modules-load.d/8192cu.conf
Then
sync
reboot
Tried that already it says cannot find 8192cu
I missed the quotes, so sorry
- Code: Select all
cat "8192cu" > /etc/modules-load.d/8192cu.conf
pepedog wrote:I missed the quotes, so sorry
- Code: Select all
of course already tried that. "cat: 8192cu: No such file or directory" still
- Code: Select all
echo "8192cu" > /etc/modules-load.d/8192cu.conf
I'm going mental today and shouldn't be trusted, what am I thinking?
Sorry again
pepedog wrote:
- Code: Select all
Sorry again
was just about to reply and tell you i used echo
