My new custom build.
http://www.mediafire.com/?10456ccz13ard
- OpenElec build r13076
- Xbmc Frodo build RC3 (22.01.2013) with 3d double framerate fix
- Rpi kernel 3.6.y (22.01.2013)
- Rpi firmware (22.01.2013)
- Pvr Addon (18.01.2013)
- Xvdr Addon (11.01.2013)
- Gpu memory set to 100mb on default (fix kernal killing Xbmc task on Rpi 256mb board)
- Memory cache set to 2621440 on default
- GUI resolution switch (taken from XBIAN)
Add to advencedsettings <guires>XXXX</guires>
XXXX = GUI resolution. 480p,720p,900p,1080p. <guires>720</guires>, <guires>1080</guires> etc...
Update Instruction:
http://openelec.tv/installation/updating
For Rpi 512Mb set gpu_mem=256, cachemembuffersize to 5242880 and change GUI to 1080p.
For Rpi 256Mb set gpu_mem=100, cachemembuffersize to 2621440 and change GUI to 900p.
or clean install:
http://wiki.openelec.tv/index.php?title ... spberry_Pi
OpenElec Builds with GUI 1080p.
Like to try your openelec file of 03/01/2013.
Only question I have, is it stable. Because a lot of version got stuck and a reboot is necessary.
Try last version. r22012013. Is stable as rock.
Thank you for the excellent builds!
My only issue is usually the initial library scan / import from SMB.....usually just locks up after a bit of scanning / importing. I think part of it had to do with my CPU values though. Once I bumped them back down to defaults I was able to complete a scan. The other problem is probably dealing with SMB in general.
- OpenElec build r13108
- Xbmc Frodo Final !!! (27.01.2013) with new video codecs:MJPEG, VP6, VP8, Ogg Theora and audio codec: Ogg Vorbis for Rpi.
- Rpi firmware (26.01.2013)
- Gpu memory set to 100mb on default for Rpi 256mb (fix kernal killing Xbmc task on Rpi 256mb board) and Gpu memory set to 256mb on default for Rpi 512mb.
Update Instruction:
If you want try new codecs add this line to config.txt
start_file=start_x.elf
fixup_file=fixup_x.elf
or clean install:
Update Instruction:
or clean install:
How do i clean install your builds to a sd card using windows.... ?
- OpenElec build r13137
- Xbmc Gotham 13 (30.01.2013) with new video codecs: VP6, VP8, Ogg Theora and audio codec: Ogg Vorbis for Rpi.***
- Rpi kernel 3.6.y (30.01.2013)
- Rpi firmware (30.01.2013)
- Xvdr Addon (29.01.2013)
Update Instruction:
or clean install:
Update Instruction:
or clean install:
Am i invisible or you just being ignorant?
No. I miss your post.
I dont now how install my build on Windows. I alway use Linux.
Rbej Frodo Final Version 2
- OpenElec build r13143
- Xbmc Frodo 12 Final with new Rpi patch:
- new video codecs: VP6, VP8, Ogg Theora and audio codec: Ogg Vorbis for Rpi.***
- Avoid blocking the video thread keeping the video fifo full. https://github.com/xbmc/xbmc/pull/2158
- Rpi kernel 3.6.y (01.02.2013)
Update Instruction:
or clean install:
Update Instruction:
or clean install:
by rbej » Sat Feb 02, 2013 2:55 am
I second this, I've always used the script to install this on my SD. You could always boot to a live CD and run it?
I installed your versions and they are working great.
Now downloading Rbej Frodo Final Version 2.
thanks great job
@flunkyou2 : just download the versions, unrar them. In folder target you'll find the four files (Kernel, Kernel.md5, System and System.md5)
follow this site instruction to update : http://wiki.openelec.tv/index.php?title ... g_OpenELEC.
good luck
thanks great job
good luck
Is it even possible to get flv streams working,i get only audio, no video. even after this update:(
You add this line to config.txt ??
Hi rbej,
Maybe that is a strange request. But could you incorporate a very small fix into your builds? In Frodo final, there is a bug that prevents the use of the library with webdav sources. You would only have to change one file, described in the following link:
https://github.com/xbmc/xbmc/pull/2132/files
I don't know if you've got the time, but I would appreciate it greatly!
Cheers!
Cheers!
Rbej Gotham Version 2
- OpenElec build r13165
- Xbmc 13 Gotham Alpha 1 (03.02.2013)
- Rpi firmware (03.02.2013)
Update Instruction:
or clean install:
Update Instruction:
or clean install:
I followed this update instruction.
It seems that only possibility to get codecs working is installing it from Linux machine.
Anyway why is the .flv not supported by default? Licence issue, like v1/mpeg2?
defer wrote:@flunkyou2 : just download the versions, unrar them. In folder target you'll find the four files (Kernel, Kernel.md5, System and System.md5)
good luck
Rbej Gotham Version 2 includes the webdav patch! Very nice release, thanks!
Good Day, I downloaded and installed his version, I am using Navi-X, and when I select a stream of live TV, when I select to change the language, it freezes, if I leave it alone, it's fine, but once I select to change the language from Russian to English it freezes.
Using the rPI with 512, any help would be appreciated.
Maybe X-Navi dont work propertly with Xbmc 13 Alpha. Try Frodo Final version 2.
Thanks for the reply, I looked at the status page in XBMC and even though it has compile date of Feb 2, it shows XBMC 12.0 Git:fb595f2 (Compiled: Feb 2 2013)
Rbej Frodo Final Version 2.5
- OpenElec build r13180
- Xbmc 12 Frodo Final with PVR fixed. (Thx Jbree85)
Update Instruction:
or clean install:
Update Instruction:
or clean install:
Rbej Frodo Final Version 3
- OpenElec build r13227
- Xbmc 12.0.1 Frodo Final
- Rpi kernel 3.6.y (07.02.2013)
- Rpi firmware (07.02.2013)
- Pvr Addon (18.01.2013) with PVR TvHeadend 1.6.18 fixed. (Thx Jbree85)
- Xvdr Addon (07.02.2013)
Update Instruction:
or clean install:
Update Instruction:
or clean install:
can someone provide step by step instruction how to install this build in linux?
Hi Rbej. the links for insruction how to install/update Openlec u posted dont really explain how to install custom builds. What do u do with config.txt, and whole bootloader folder?
