Hi All !
As i was preparing for may first attempt at compiling anything ever * i remarked that my a's came out as q's . After some searching on this forum i hit on a subject** and posted this :
Quote/
Am having the same problem as Johann : Belgian keymap (azerty iso qwerty, etc) is used in the console, but as soon as i use X lxde the mapping reverts to qwerty . This is on a fresh install of the official raspbian, with latest updates of firmware, software et al .
I also installed an sd card with pisces MATE R2, did all the updates and upgrades, and Bingo! Qwerty in the GUI . In MATE one can set the keymap in the preferences, but this shows the be(lgian) map duly set .
I can't recall having this problem when i first installed the official raspbian image, few hours after it came out, so it's got to be one of the upgrades to the x innards thats the culprit, hence this mayday call .
end quote/
I have rewritten the MATE sd-card with an original raspbian image and can confirm remapping works correctly in an un-upgraded X-lxde session on my machine . I can keep this image for now to run some upgrade tests, but don't know where to start . The fully upgraded wheezy armel image that i also have does not exhibit this flaw btw .
Thanks for reading .
Binson
* want to compile Synergy 1.4.10 on PI to be able to use it as server with my Macbook as client, but thats andother story
**http://www.raspberrypi.org/phpBB3/viewtopic.php?f=50&t=7278&p=163542#p163542
Keyboard remapping broken on X-windows ?
I have the same problem,
(keyboard mapping is in gnome different to bash, qerty istead of qwertz (german)),
and i can't find an option in gnome to change the remapping. there is no option in settings.
Has anybody made an custom xorg.conf or an other solution?
Thanks!
Thanks!
I've found an workaround:
inserting the line
in the file /etc/X11/xinit/xinitrc
(before calling . /etc/X11/Xsession) helps.
You have only to insert the mapping at the end of the line.
inserting the line
- Code: Select all
setxkbmap -option grp:ctrl_shift_toggle,grp_led:scroll de,de
Hi All !
Thanks thsBavR10 for putting me on the right track .
The file you mentioned did not have any entries so i just added in
setxkbmap be
and it worked !!!
Forcing it in this way does not explain what, or how, it got broken in the first place though .
Hmmm ...
Bye for now .
Binson
setxkbmap be
and it worked !!!
Hmmm ...
Bye for now .
Binson
I am pleased that it has helped.
But this is, as you wrote, only a workaround, not a final solution.
Something has broken between the individual changes at the console to locale and keyboard-mapping and so on,
and the X11 / LXDE.
Don't know, where to adress this error (maybe in the rasbian board).
and the X11 / LXDE.
I can confirm this problem. I'm not sure when I last time typed something in X, I noticed this only now.
Same problem for me, mz swiss kezboard work fine under the standard bash but switch to Uk or US kezboard as soon as I run LXDE, as zou can see
thsBavR10 wrote:I've found an workaround:
- Code: Select all
Thanks, it work for me except that I used the Swiss - French keyboard
setxkbmap -option 'grp:ctrl_shift_toggle,grp_led:scroll' 'ch(fr)'
My problem is my Swiss German does work right from the start.
BUT the Alt Gr button will not work - so I cant get a backslash or AT symbol.
I have run "sudo raspi-config" and set the k/b again (configure_keyboard) but to no avail
AltGr is working for me, both on commandline and in X11.
What does your /etc/default/keyboard contain regarding XKBMODEL ?
I also have this file:
- Code: Select all
XKBMODEL="pc105"
- Code: Select all
cat /etc/X11/xorg.conf.test :
# only sectionInputDevice for testing
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "Xkblayout" "de"
EndSection
My Alt Gr key works now.
I didnt do anything to get it going it just started working. I did change the power supply on the pi to a hub and connected the wireless USB transmitter to the hub, it could have been a power issue.
Here's my config file anyway:
- Code: Select all
cat /etc/default/keyboard
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="logicda"
XKBLAYOUT="ch"
XKBVARIANT=""
XKBOPTIONS="lv3:ralt_switch,terminate:ctrl_alt_bksp"
BACKSPACE="guess"
