http://qt-project.org/wiki/RaspberryPi_Beginners_guide and i’am stuck at ./configure step with following errors:
- Code: Select all
<srcbase> = /home/pi/opt/qt5/qtbase
<outbase> = /home/pi/opt/qt5/qtbase
Creating qmake. Please wait...
make: Nothing to be done for `first'.
Warning: Disabling pkg-config since PKG_CONFIG_LIBDIR is not set.
Note: PKG_CONFIG_SYSROOT_DIR automatically set to /mnt/rasp-pi-rootfs
Determining architecture... ()
/home/pi/opt/gcc-4.7-linaro-rpi-gnueabihf/bin/arm-linux-gnueabihf-g++ -c -pipe -marm -mfpu=vfp -mtune=arm1176jzf-s -march=armv6zk -mabi=aapcs-linux -mfloat-abi=hard --sysroot=/mnt/rasp-pi-rootfs -g -Wall -W -fPIE -I../../mkspecs/devices/linux-rasp-pi-g++ -I. -o arch.o arch.cpp
/home/pi/opt/gcc-4.7-linaro-rpi-gnueabihf/bin/arm-linux-gnueabihf-g++: 1: /home/pi/opt/gcc-4.7-linaro-rpi-gnueabihf/bin/arm-linux-gnueabihf-g++: Syntax error: "(" unexpected
make: *** [arch.o] Error 2
Unable to determine architecture!
Could not determine the target architecture!
Turn on verbose messaging (-v) to see the final report.
g++ -c -pipe -g -Wall -W -fPIE -I../../mkspecs/linux-g++ -I. -o arch.o arch.cpp
g++ -o arch arch.o
{ test -n "" && DESTDIR="" || DESTDIR=.; } && test $(gdb --version | sed -e 's,[^0-9]\+\([0-9]\)\.\([0-9]\).*,\1\2,;q') -gt 72 && gdb --nx --batch --quiet -ex 'set confirm off' -ex "save gdb-index $DESTDIR" -ex quit 'arch' && test -f arch.gdb-index && objcopy --add-section '.gdb_index=arch.gdb-index' --set-section-flags '.gdb_index=readonly' 'arch' 'arch' && rm -f arch.gdb-index || true
Found architecture in binary
CFG_HOST_ARCH="arm"
CFG_HOST_CPUFEATURES=""
System architecture: 'unknown'
Host architecture: 'arm'
C++11 auto-detection... ()
/home/pi/opt/gcc-4.7-linaro-rpi-gnueabihf/bin/arm-linux-gnueabihf-g++ -c -pipe -marm -mfpu=vfp -mtune=arm1176jzf-s -march=armv6zk -mabi=aapcs-linux -mfloat-abi=hard --sysroot=/mnt/rasp-pi-rootfs -O2 -std=c++0x -Wall -W -fPIE -I../../../mkspecs/devices/linux-rasp-pi-g++ -I. -o c++11.o c++11.cpp
make: *** [c++11.o] Error 2
C++11 disabled.
a lot of errors about disabled libs
OpenGL ES 2.x auto-detection... ()
/home/pi/opt/gcc-4.7-linaro-rpi-gnueabihf/bin/arm-linux-gnueabihf-g++ -c -pipe -marm -mfpu=vfp -mtune=arm1176jzf-s -march=armv6zk -mabi=aapcs-linux -mfloat-abi=hard --sysroot=/mnt/rasp-pi-rootfs -O2 -Wall -W -fPIE -I../../../mkspecs/devices/linux-rasp-pi-g++ -I. -I/mnt/rasp-pi-rootfs/opt/vc/include -I/mnt/rasp-pi-rootfs/opt/vc/include/interface/vcos/pthreads -o opengles2.o opengles2.cpp
make: *** [opengles2.o] Error 2
OpenGL ES 2.x disabled.
The OpenGL ES 2.0 functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR_OPENGL_ES2, QMAKE_LIBDIR_OPENGL_ES2 and QMAKE_LIBS_OPENGL_ES2 in
/home/pi/opt/qt5/qtbase/mkspecs/devices/linux-rasp-pi-g++.
i'am trying on fresh raspbian installation, tried everything from troubleshooting section. i don't get that syntax error in arm-linux-gnueabihf-g++
please help
