Can a raspberry pi connect to TFT LCD?
by Eleenwhite » Thu Aug 23, 2012 9:35 am
I had a raspberry pi on hand, and now I am wondering if it can be connected to a 3.2" TFT LCD touch panel.
http://www.sainsmart.com/home-page-view ... -2560.html
If yes, that would be wonderful. It's like a homemade ipad. :lol:
by davethewave » Thu Aug 23, 2012 2:46 pm
I hope so!
it seems that a similar display can be attached:
http://www.youtube.com/watch?v=nMQJmVDgAl8
bye
by Eleenwhite » Wed Aug 29, 2012 3:44 am
Can this 1.8" SPI LCD be connected to RPI?
by jamesh » Wed Aug 29, 2012 5:59 am
At this stage, any panel would need to connect either to the HDMI or VGA port. Although there is a dedicated TFT connector on the board it's not currently available for use. Foundation hopes to sell/promote a tested TFT once all tht other stuff is done!
Moderator
by Michael Meissner » Wed Aug 29, 2012 12:10 pm
If you just want to use a display without all of the challenge of getting a display to work from the various pins, you might want to search around for small displays that take either composite or HDMI inputs. Adafruit.com has several displays that take composite. I have a MP4 player from JXD that is fairly small and does video input that I've been meaning to use when I get to the r-pi.
by darryl » Tue Nov 27, 2012 11:19 pm
Eleenwhite wrote:Can this 1.8" SPI LCD be connected to RPI?
Yes it's ST7735 based like the Adafruit ones. I've got one with an Sainsmart Arduino UNO from China, comes with the ST7735 code for the Arduino by LadyAda.
by pygmy_giant » Wed Nov 28, 2012 12:28 am
wow - thats good for the price
by SunshineSunlight » Tue Feb 05, 2013 7:30 am
This is a video about it.
http://www.youtube.com/watch?v=-pP4ee08aJ0.
And this this a post details Adafruit 1.8 LCD and SainSmart 1.8 LCD
http://www.whence.com/rpi/
by notro » Tue Feb 05, 2013 10:11 am
I have started a project writing framebuffer drivers for small TFT LCDs. I have written a helper module that greatly simplifies writing such a driver. That is if the display is RGB565 and uses SPI. I have ordered two more modules that I will try and make drivers for:
* Nokia 5110/3310 monochrome LCD: http://adafruit.com/category/63 (challenge: monochrome, 1 bit per pixel)
* ITDB02-2.8: http://imall.iteadstudio.com/display/tf ... 19009.html (challenge: parallel databus, no SPI)
Project page: https://github.com/notro/fbtft
Wiki: https://github.com/notro/fbtft/wiki
Currently the wiki is just my own notes made pretty.
by texy » Tue Feb 05, 2013 3:15 pm
notro wrote:I have started a project writing framebuffer drivers for small TFT LCDs. I have written a helper module that greatly simplifies writing such a driver. That is if the display is RGB565 and uses SPI. I have ordered two more modules that I will try and make drivers for:
Note that the Nokia type display has hardware SPI python code already, but if you can create a faster C++ driver for it, that would be awesome ;-)
viewtopic.php?f=32&t=9814
Texy
"!.8inch TFT LCD + Switch Shield" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=59&t=40674
50p goes to the Foundation ;-)
Moderator
by notro » Tue Feb 05, 2013 4:53 pm
Yes I was aware of that. The driver I will make is a framebuffer driver, a video driver.
It's the same type of driver that gives video output on the PI:
# Show info about /dev/fb0
fbset -i
mode "656x416"
    geometry 656 416 656 416 16
    timings 0 0 0 0 0 0 0
    rgba 5/11,6/5,5/0,0/16
endmode
Frame buffer device information:
    Address     : 0x4c006000
    Type        : PACKED PIXELS
    Visual      : TRUECOLOR
    XPanStep    : 0
    YPanStep    : 0
    YWrapStep   : 0
    LineLength  : 1312
    Accelerator : No
This the Adafruit 2.2" display supported by fbtft:
fbset -i -fb /dev/fb1
mode "176x220"
    geometry 176 220 176 220 16
    nonstd 1
    rgba 5/11,6/5,5/0,0/0
endmode
    Address     : 0
    Visual      : TRUECOLOR
    XPanStep    : 0
    YPanStep    : 0
    YWrapStep   : 0
    LineLength  : 352
    Accelerator : No
It will fun to see if I can play video on the Nokia display using mplayer :)
